AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Stand suggestions for new 54" plasma
post #1 of 3
Just bought my first HDTV, a 54" G10 and need to find a stand. Anyone know of any good deals? I've seen some with back mounts so I'm guessing this is to help prevent tipping. My budget is pretty lean so any advice would be great. Thanks.
post #2 of 3
If you go with a table top placement, go with a glass top/ metal frame. I have found the wooden cabinets always bow in the middle, which looks like crap. I bought mine from BB when it was on a good sale.
I would say find the model you want and then shop for prices. Make sure it has the shelf/ ventilation clearance for your other gear. I have a very tall center channel speaker and it took me a while to find the unit I wanted/required. I also wanted my TV screen height to be as close to my eye height when sitting down.
really try to think about everything you need. Forgetting one thing can really suck!
post #3 of 3
Thanks for the tips. Been looking around and notice the Bell'O stands come up pretty regularly. Like the looks of this one with the wood accent (for just under $300):
Noticed there's no back mount so not sure how important it is for the 54" plasma.
