AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon AVR 3808CI On Screen display gone!
post #1 of 5
Just noticed today that my on screen display is gone via HDMI. I was playing a bluray and noticed that when I changed the volume, it did not appear on the screen, only on the receiver. I then tried to display the menu with no luck. Anyone else having this problem? If so, is there a resolution?
post #2 of 5
Turn power all the way off, small power button. Then of course back on. Think reboot for your computer.
post #3 of 5
Bingo! We have a winner! Thanks!
post #4 of 5
Reboot worked for me too!!! Just unplugged power cable from the back of the receiver and plugged it back in. Thanks!
post #5 of 5
Power cycle worked for me too!
