AVS › AVS Forum › Gaming & Content Streaming › HD Radio › Revised IBOC power calcultor is now available (NPR Labs)
post #1 of 4
This is an updated version (Nov 17 2009) which allows greater power increase compared to its earlier NPR Labs calculator released in July.
It's available here http://www.nprlabs.org/publications/...nce/index2.php
It's not officially released yet but I found I can enter the station and get allowable power increase information. The data may not be fully correct yet as I believe they are populating the database as we speak. But the detailed info in the Results section seems to indicate quite a few station will get the full 10 dB increase (10X the digital power) This is wonderful if that's the case
post #2 of 4
Appears to be offline again but here's the results for WHOM FM which I captured earlier.
IBOC Candidate Station
Call Sign
WHOM
IBOC Power Limit (dBc)
upper
lower
WHOM
MOUNT WASHINGTON,NH
Results where station WHOM is the Proponent Station Candidate Call Sign: (reserved band)
Candidate Application ID:
Candidate Class:
Candidate Channel: (47.9MHz)
1st UPPER Adjacent Call Sign: WBAR-FM (LAKE LUZERNE,NY)
1st UPPER Adjacent Application ID:
1st UPPER Adjacent Class: A
1st UPPER Adjacent Channel: 234 (94.7MHz)
Bearing, in Degrees True...
From Candidate Station to 1st Adjacent Station: 241
Distance (kilometers)...
IBOC Power Limit: -10.0dBc
Candidate Class:
1st UPPER Adjacent Call Sign: WVTQ (SUNDERLAND,VT)
1st UPPER Adjacent Channel: 236 (95.1MHz)
From Candidate Station to 1st Adjacent Station: 229
post #3 of 4
I can not wait to test the signal after increase. Wish they could Help AM - HD more to...
post #4 of 4
It's up again at http://www.nprlabs.org/publications/...nce/index2.php
This time they have better data. Here's a screeenshot of WILV 100.3 FM Chicago which would have the full 10 dB increase on both sidebands.
  Back to Forum: HD Radio
