AVS › AVS Forum › Audio › DIY Speakers and Subs › Tuba Home Theater Build
Tuba Home Theater Build - Page 5
post #121 of 230
Originally Posted by Fatawan View Post
I find some of the claims for the THT somewhat, ummmmm, unbelievable. Such as this quote directly from the website:
Not impressed yet? Add in the cabin gain of an average room (12dB per octave below 30 Hz) and you end up with flat response to 1Hz with 110dB sensitivity. Not even the most expensive theatrical subs made can make that claim.
Flat to 1Hz....with the $150 driver.....and some cheap plywood....ok
You should try one. You may be surprised
post #122 of 230
It would be even flatter with 50db between hash marks, but only a wee bit more misleading than the 30 you show. I prefer the reality of the graph bosso posted in your thread.
http://www.avsforum.com/avs-vb/showt...8#post17493538
post #123 of 230
Fatawan,
Astute observation. The Table Tuba page also says "You want a horn loaded home theatre sub that can deliver over 110dB at 20 Hz". IMO, both of these claims are not responsible, and are there to lure audio knowledge deficient folks into buying plans (worked for me when I bought the TT plan almost 2 years ago).
The TT may hit 110dB at 20Hz, but with so much THD that it would sound like total ass. I can only get low 80s dB-wise at 20Hz before I decided that more power in was not the answer to good sound for a TT. A good highpass is.
The THT may be able to do the 1Hz thing in a sealed concrete bunker, but saying that 1 Watt will give you 110dB at 1m at 1Hz in a typical room is kinda 'off', IMO. The quotes further down the page for the THT both say that useful output for the THT is in the teens (one of them mine), so that should temper the 1Hz claim.
The 1Hz claim is even stranger coming from the very person who does not believe that sub-15Hz content is important.
"A word about response below 15 Hz.
If you have a speaker capable of doing so, and the necessary test gear, run a 12 Hz sine wave though the system to a 105dB level, outdoors so that you'll hear the speaker and not the house vibrating around you. Do an RTA to see what's in the output; if you have a direct radiating speaker you'll see that you don't have a pure 12Hz sine wave, you've got 12Hz plus a lot of harmonics. If you've got a folded horn the harmonic content will be lower, but it will still be there. And now, as to what you'll hear: not much. If not for the meter telling you it's there, and the whoosh of air rushing about, you'd be hard pressed to tell that there's anything there at all. What you do hear is those harmonics. And that's why I'll never build or design a cab with the intent of going lower than THT, unless one of you is nuts enough to pay me my $2,000 one-off fee.
Yes, some DVDs have content below 15 Hz, and measuring gear can detect it. You can't. If you think you can that's all well and good, but just as you can't get around the physics of how large a speaker must be to reproduce those frequencies you also can't get around the physics of how large your eardrums, ears and head must be to hear them. If you crave the low frequency vibrations, get some Butt Shakers"
That being said, these designs DO NOT NEED these exagerrated claims. They work VERY well. They are great bang-for-buck. If you are on a budget, I cannot think of a better deal. If you need above 30Hz, TT. If you want more extension and volume, THT. Just like any other design, they have strong points and weak points.
If you have stud and drywall walls, you won't get as much room gain as myn gets with cinder block construction.
Either way, how else can you get low distortion playback to 20Hz (and depending on your room, lower than 20Hz) at reference level at your listening position for $400?
JSS
post #124 of 230
I saw myn was putting 16v into his dvc 15" to break it in, i can't seem to put more than 10v into it without the suspension complaining.. the excursion looks like two centimeters?
post #125 of 230
Depends on the frequency you are using for break-in and how you are wiring up the coils...
JSS
post #126 of 230
Ohh aight. I'm using 20hz and i wired em up into 4 ohms.
post #127 of 230
Originally Posted by Vinculum View Post
What does the phase response look like on the THT? Is it comparable to a sealed direct radiator?
Dr V
Originally Posted by Bill Fitzmaurice View Post
IMO moot, you can't hear it.
I was hoping for a more technical answer. Such as what is the phase shift over a specific range. Say for example slightly below the horn loading range to the upper LFE channel specification 16Hz-120Hz? I suppose I could figure out how to model it if you want to keep it a secret.
Dr V
post #128 of 230
Dr V
It's no secret, it runs 45 degrees at 20 Hz, 0 at 25 Hz, -90 at 100Hz. But since it's not audible it's not something I concern myself with.
post #129 of 230
Update, all the glue is drying. Tomorrow hopefully i will take out all the screws, roundover the edges, fill and sand all the edges/holes, then primer and paint. I think i'm gonna use the orange peel spray on stuff from home depot and then plain black paint on top of that, nothing fancy and easy to fix. Ohh and i still need to make the access panel mounting thingys.
post #130 of 230
Is the only way to make uniformly round those edges is with a router?
post #131 of 230
Dr V
*very roughly*, it looks about like this.
post #132 of 230
post #133 of 230
Why didn't you use the hurricane nuts?
post #134 of 230
I used the barbed inserts that rightbrained sent me.
post #135 of 230
nice job revolt.
thanks for posting the pics.
you can probably remove the screws, but i would pl all the holes and then sand flush. you may have one or two screws that missed the mark and so would let out air if not filled in.
post #136 of 230
Interesting. I don't think I've seen those before.
post #137 of 230
Another way I can think of doing it is with a sanding block that is contoured to the roundover you want, use spray adhesive to mount the paper to it, or just manually sand the roundover with a flat block. You'll be surprised how good you can make one with a little practice.
The easiest way is with a router. They are very handy tools.
JSS
post #138 of 230
Air Supply,
Drill a pilot hole then hammer 'em in.
dbl
post #139 of 230
Bill, Thanks for the data. Its about what I expected, no complaints!
LTD, Thanks for the graph too.
Looking good Revolt. I'm anxiously awaiting the reviews and possible measurements from these builds.
Dr V
post #140 of 230
Looking real good!
You're on the home stretch.
post #141 of 230
Thanks! Yeah for sure, hoping to finish by tomorrow. I just rounded the edges over and it looks goooood! And i picked up the wood filler and orange peel finish.
post #142 of 230
More pics.. hopefully this wood filler will dry strong enough? :/
post #143 of 230
Did you use a router for those edges? Did you end up removing all of the screws?
post #144 of 230
Yea i used a router with what i think is a half inch roundover bit. and yeah i removed all of them and shot 18 gauge nails just in case then put wood filler in all the holes.
I put the orange peel finish on too thick, so i ran out with 2 sides left. I'm gonna be pretty busy tomorrow so i might have to finish this on tuesday.
post #145 of 230
Gonna get more orange peel finish today and hopefully put it all together. I was breaking in the driver and couldn't seem to put more that 10volts into it without what i thought was the suspension complaining. Turns out it was one of the tinsel leads rubbing against the cone. I pushed it with a pencil and was able to put about 14-15 volts into it. This thing can move more than i thought.
post #146 of 230
that might confuse people. they are screwed in with a hex drive.
post #147 of 230
I hammered mine in.. you can pull em through with the cap head and a hex bit or just hammer them from the other side.
painting finally. taking forevvvvvvvver. i want this done! arg.
Well guess what i did.. Ripped the gasket off the driver! I was thinking ahh it needs to be airtight, i'll use some double sided tape, i put the driver in a litle off so i went to pull it back out and the cardboard gasket just fell apart. I was freakin out. But with some super glue all seems well and i bolted it in the sub and tested it a lil. At this point it was 1am so i couldn't turn it up much. Plus the access panel was still off, so today should be much better. I should be posting some impressions later tonight.
post #148 of 230
I'M DONE! So heres the situation. I wanna know what this thing can do. But after reading on bills forum about the tubas, its different than i normal sub cause you can't see when its about to bottom. So idk how to go about increasing the level. Its like a new car and idk how much i can press on the gas. Any help?
post #149 of 230
Excellent!!!
I think the first thing you should do is check for leaks. Play a low tone at a low volume and you'll hear it for sure. I ran 10-20Hz tones at a very low volume and could hear a small one right around the access panel.
dbl
post #150 of 230
If you have a high pass filter enabled I would say punch it .
