AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Settings for Polk PSW 505 and Onkyo TX-SR607
post #1 of 3
My front speakers in Def Tech BP6s. Would you recommend using the Sub Out on the 607 or connecting them in parallel using the speaker outputs. The BP6s can put out some really good bass. Any recommendations would be immensely appreciated. Thanks.
post #2 of 3
I'd say use the sub pre-out on the onkyo and run the Audyssey setup for the whole system. I'm thinking about adding the Polk PSW505 to my PSW110 and PSW125. How do you like it?
post #3 of 3
I'm running a PSW 505 sub with an Onkyo 707 receiver. Its powered from the Onkyo's sub-out and sounds more than acceptable to me.
