I had good luck fixing my Panasonic TH-42PA20, thanks to information I found here at AVS.
So, I thought I'd try it again: I've got a Sony KDL-52Z5100 with a dead screen. Sony has warranteed the unit out, the replacement is installed, and they've received the tag I took off the back. So this is mainly for curiosity and tinkering.
The issue was gradual: a section of the screen went blocky, then a larger section, and finally the whole thing went dead. Unlike the TH-42PA20, which had a few known problems that a lot of people had worked with, I haven't been able to find much about the KDL-52Z5100 or its innards.
As an aside: Sony charges $7000 (that's SEVEN THOUSAND) for a replacement LCD panel! Still trying to figure out exactly how that works for a TV that retails for under $2K
