ACI had a weekend sale back in the summer and I was lucky enough to grab four 15" sub drivers from them. They're pretty nice looking units that were used in their Maestro subwoofer. But they stopped making the Meastro and sold the remaining drivers for a great price.
I wanted to do something that looked a bit nicer than my last subwoofer build so more time was spent designing the enclosure and a lot of time experimenting with the final finish on spare wood prior to the build. I figured out a method that will allow anyone to get a mirror shine without any hard work......no sanding, and best of all, it can be done in your own living room.
Yeh, I know that sounds hard to believe. But just to keep you interested, I'll post one of my experimental boards. Now this trial actually had 2 experiments going. If you look close on the right side reflection, you can see some roughness, that was the other half of the board.
The pin in that one always seemed real tight and as I lifted it out of the wood. The plastic cracked right where it was screwed into my router and actually fell off. I do have a tendency to over tighten screws, so I'm guessing that didn't help much either. Regardless, after it broke, I got aggravated and found out that it flies pretty far when you throw it like a frisbee. It's somewhere in the back yard. If I don't find it by spring, the mower surely will.
