Originally Posted by thezaks
Hi penngray,
I do understand what you are getting at, and I agree with you that subjective opinions could be tainted and could lead down a wasted $$$ path. What I'm not sure about and I'm hoping you can explain is the parameters for what you consider "controlled listening tests". It's possible that I abide by those, but it's also possible that I do not abide by those. Could you help me out and let me know what you consider to be controlled listening tests?
Thanks so much,
Dave
Hi penngray,
Thanks so much,
Dave
I wish it was easy to just do a controlled test but it isnt. For this type of mod a controlled test would include the following.
1. The original equipment and the modded equipment side by side but hidden from you so that you do not know which one is being used.
2. Level Matching done to ensure loudness levels are accurate. Some mods just increase decrease loudness. Amazingly people think that is an SQ change.
3. Someone use switches the equipment and you do not see them doing it our their expressions.
This is a start on how to control the tests, People will argue its still not scientific enough, its still not accurate enough but the main point here is that all we are simply trying to remove external influences on our audio experience.
I also always would measure any content from both sources to see if there are measured differences. If there are obvious audible differences, then there are going to be measurement differences backing up those obvious audio difference. If there isnt any measured differences then the audible differences are actually that obvious and its really just a placebo type of difference (ie. some people are going to think its a HUGE difference).
I actually have no problem with anyone's subjective experience being their tool for their purchasing decisions. My main pet peeve is that people will read your very well written but subjective opinion and take it as fact.
They will then spend money based that subjective opinion. Your opinion, along with other "positive marketing" spin almost always convinces a high, high percentage of people search to improve their setup no matter how silly it may seem....they eat that stuff up, its their koolAid
I'm sure they're also aligned in such a way that they can predict eclipses and the changing of the seasons too. Which one ponts to the north star?
