Originally Posted by
rickardl
Not Joe but it will probably look something like this:
Code:
[Audio] DVD/BD
Input : HDMI 1
Dolby D 48Khz
5.1ch
Output: THX Ultra2 Cinema
7.1ch
[Video] DVD/BD
Input : HDMI 1
720x480i 60hz YCbCr 24bit
Output: HDMI Main
1920x1080p 24hz YCbCr 24bit
ISF : Custom
but dialog norm offset is only flashed initially on the front panel display.
joerod
Perfect.
Joe.. since you have their ear, it would be a great feature (dialog norm on the OSD) to add in for two reasons.
1. Since it isn't compensated for by the processor, the end user needs to know what it is so they can raise or lower the volume accordingly... IMO, it's the most important piece of data in the stream.
2. It can change over the course of a disc or broadcast... it cannot change within a program/title, but commercials, trailers, etc can be different on the same station and even DVD's and BR's.... I watched a show with my girls today on DVD, and each trailer was different from the feature... 4 offsets from the start of the disc.
and to be a real pain, tell them that all the new Denon's and Yamaha's show it on their OSD.
