I have a 7 1/2 year old Mitsubishi WS-65869 which has functioned quite well until recently.
The power in our neighborhood went out for several hours, and when it came back on, the Green light on the set blinked continuously, and didn't turn off as it normally would after a power loss. Unplugging, System Reset, giving it time, etc. made no difference.
I researched this and found that Caps in the DM Module might be the likely problem. I chickened out on repairing it myself, and had a guy come. He took the 'guts' with him, and later said he replaced Caps in the DM Module, along with a bunch of other stuff (but who knows).
He came back, put everything back together, and it turned on normally, and I thought I was good to go. The next day, while watching TV, it abruptly turned off without warning. No blinking light. I tried to turn it back on: the Green Light comes on (with the usual spring-like noise), stays on for 1-2 seconds, and then turns off. Nothing ever comes up on the screen. Unplugging, System Reset, no change. Can't turn it on and have it stay on.
I am only $100 in the hole so far, paying the guy for the first service call, and he's sending me the $300 check I wrote to him for the rest, saying I can't help you any more.
So I need to figure out what to do next, or whether or not to sink any more money into this set. I otherwise love it, and really don't want to be a new one. So:
1. Any specific ideas on what the problem might be, and whether or not it will be cost-effective to fix?
2. Am I postponing the inevitable, and that like an ageing automobile, it might be time to just cut loose and move on?
