I read on wikipedia that anti-aliasing is when a higher resolution is fit to a smaller resolution.
The video card frame buffer/ ram, needs to be enough so the videocard can do anti-aliasing properly.
This frame buffer/ram, isn't so important in pcie 2.0 or 2.1, but in pcie 1.0 16x the frame buffer on the video card is the only ram available, it holds the video frame and enables things ike anti-aliasing to be done to the frame.
In pcie 1.0 16x if you have a 2k source frame being anti-aliased to 1080p and you don't have enough video card ram to do this properly you will have anti-aliasing issues.
So my question is, is blu ray 2k on the disk, or do they anti alias it at the factory to 1080p?
but I think they usually crop). Some films are scanned at 4K or higher.
