Just curious if there is anything out there in DIY land that will dig deep (10-15Hz), cost effective, and comes in kit form for somebody without any wood working tools (pre-cut/built cabinet)?
Something much less expensive than the Danley DTS-10, I know that's a killer kit but looking for a less expensive solution if it's out there
Already have 4 powered subs in my HT (2 are used for mid-bass) and have 25Hz+ covered, need something to fill in the LOW end so it could even be tuned/ported low with less performance above 30Hz.
Thank You,
Jason
.Already have 4 powered subs in my HT (2 are used for mid-bass) and have 25Hz+ covered, need something to fill in the LOW end so it could even be tuned/ported low with less performance above 30Hz.
Thank You,
Jason
