Originally Posted by
shane2943
Well, the 2009.1 version won't work due to an unresolved dependancy:
Code:
[root@localhost Downloads]# urpmi ./mediainfo-0.7.25-1.i586.Mandriva_2009.1.rpm
A requested package cannot be installed:
mediainfo-0.7.25-4.1.i586 (due to unsatisfied libmediainfo.so.0)
Continue installation anyway? (Y/n) n
Of course it won't work you have to download the dependency library packages from the same site too!
It's actually 2 libraries that are needed, both are there for you to download along with mediainfo.
Edit: with regards to your MKV, it looks like you have 2 audio tracks there one is 2 channel dolby pro logic AAC (this one is there by default part of the Handbrake preset) and then the pass-through AC3 track.
You should remove the default AAC track next time, you don't need it and it slows down your transcode and it's probably the one XBMC is playing by default as it's the first track. In XBMC, during playback you can switch to the second track, then you will get 5.1 sound (but as I said, next time better remove the default AAC track and only include the AC3 pass-through track).
