Featured Stories
Léon: The Professional comparison *PIX*
AVS Top Picks
- Xylon
- Trader Feedback: 0
- LeT'sgOGeTsOMeTacos!
- offline
- 7,380 Posts. Joined 12/2005
- Thumbs Up: 11
- Select All Posts By This User
The extra contrast and brightness levels especially on some outdoor scenes can be distracting to viewers including some loss of PQ detail. This could have been a better transfer if levels are dialed down a bit.
Aside from that the Blu-ray version is better looking overall. No excessive DNR or EE observed. I just hope in future that we get the "non-boosted" version.
- Xylon
- offline
- Thumbs Up: 11
- Xylon
- offline
- Thumbs Up: 11
- Xylon
- offline
- Thumbs Up: 11
- Xylon
- offline
- Thumbs Up: 11
- Xylon
- offline
- Thumbs Up: 11
- Xylon
- offline
- Thumbs Up: 11
DVD Uncut International Version
Mpeg-2 File size: 14.00 GB
Bitrate: 17.56 mbps
Blu-ray File size: 38.00 GB
Bitrate: 25.55 mbps
Bitrate: 17.56 mbps
Code:
Sequence Summary: File Size Processed: 14.09 GB, Play Time: 01h:49m:26s 1920 x 1080, 29.97 fps, 65.00 Mbps (17.56 Mbps Average). Average Video Quality: 71.51 KB/Frame, 0.28 Bits/Pixel. AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps. Dialog Normalization: -29.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB 1 of 196795 video frames found with errors. 0 of 205199 audio frames found with errors. 513 corrupted video bytes in file. 0.000000 seconds of video timestamp gaps. 0.000000 seconds of audio timestamp gaps. End of Log
Bitrate: 25.55 mbps
Code:
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
00002.MPLS AVC 2:12:52 39,050,803,200 48,350,982,258 39.18 25.55 DTS-HD Master 5.1 5829Kbps (96kHz/24-bit)
Code:
DISC INFO: Disc Title: THE_PROFESSIONAL Disc Size: 48,350,982,258 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.3 PLAYLIST REPORT: Name: 00002.MPLS Length: 2:12:52 (h:m:s) Size: 39,050,803,200 bytes Total Bitrate: 39.18 Mbps (*) Indicates included stream hidden by this playlist. VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 25550 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 5829 kbps 5.1 / 96 kHz / 5829 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS-HD Master Audio French 2642 kbps 5.1 / 48 kHz / 2642 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS-HD Master Audio Portuguese 2631 kbps 5.1 / 48 kHz / 2631 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 23.471 kbps Presentation Graphics English 20.994 kbps * Presentation Graphics English 15.253 kbps Presentation Graphics French 21.396 kbps Presentation Graphics Portuguese 19.138 kbps Presentation Graphics Spanish 21.088 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 05001.M2TS 0:00:00.000 0:01:54.572 535,412,736 37,385 05002.M2TS 0:01:54.572 0:43:49.960 13,014,190,080 39,587 05004.M2TS 0:45:44.533 0:01:00.143 296,030,208 39,377 05005.M2TS 0:46:44.676 0:21:55.314 6,523,865,088 39,679 05007.M2TS 1:08:39.990 0:20:02.701 5,915,473,920 39,348 05008.M2TS 1:28:42.692 0:03:12.192 935,817,216 38,953 05010.M2TS 1:31:54.884 0:00:48.256 235,149,312 38,983 05011.M2TS 1:32:43.140 0:05:21.904 1,571,512,320 39,055 05013.M2TS 1:38:05.045 0:05:41.466 1,664,913,408 39,006 05014.M2TS 1:43:46.511 0:23:19.231 6,944,858,112 39,707 05016.M2TS 2:07:05.743 0:05:47.221 1,413,580,800 32,569 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:10:02.601 25,215 kbps 50,899 kbps 00:01:50.527 33,373 kbps 00:00:39.497 30,736 kbps 00:01:36.137 131,453 bytes 478,714 bytes 00:01:46.022 2 0:10:02.601 0:06:58.918 24,895 kbps 37,548 kbps 00:16:41.667 28,193 kbps 00:10:11.694 27,690 kbps 00:10:06.689 129,793 bytes 504,498 bytes 00:10:29.128 3 0:17:01.520 0:07:18.771 26,263 kbps 35,184 kbps 00:18:02.956 29,123 kbps 00:18:59.263 28,334 kbps 00:18:54.299 136,925 bytes 477,905 bytes 00:20:37.653 4 0:24:20.292 0:05:55.897 27,006 kbps 35,485 kbps 00:28:01.679 30,651 kbps 00:25:08.465 29,313 kbps 00:25:03.585 140,796 bytes 478,106 bytes 00:25:12.052 5 0:30:16.189 0:03:39.928 26,599 kbps 34,505 kbps 00:33:29.173 30,191 kbps 00:33:35.304 29,726 kbps 00:33:35.012 138,673 bytes 522,933 bytes 00:33:46.691 6 0:33:56.117 0:08:46.067 25,976 kbps 33,141 kbps 00:42:29.338 28,417 kbps 00:40:13.619 27,552 kbps 00:40:08.906 135,426 bytes 406,619 bytes 00:40:57.538 7 0:42:42.184 0:05:26.534 25,976 kbps 32,974 kbps 00:45:45.659 29,440 kbps 00:47:51.994 28,734 kbps 00:47:50.325 135,427 bytes 502,031 bytes 00:43:36.530 8 0:48:08.719 0:07:21.232 26,047 kbps 36,970 kbps 00:52:31.064 31,438 kbps 00:51:54.945 30,074 kbps 00:49:34.846 135,796 bytes 572,596 bytes 00:51:01.558 9 0:55:29.951 0:08:23.336 25,708 kbps 36,694 kbps 01:02:34.000 31,738 kbps 01:02:34.000 30,699 kbps 00:55:29.951 134,029 bytes 530,469 bytes 01:01:01.741 10 1:03:53.287 0:04:46.703 25,847 kbps 38,132 kbps 01:07:45.728 30,972 kbps 01:06:40.079 29,850 kbps 01:06:40.079 134,756 bytes 500,565 bytes 01:06:40.204 11 1:08:39.990 0:19:49.813 25,899 kbps 37,940 kbps 01:15:22.309 30,012 kbps 01:18:29.579 28,944 kbps 01:18:24.699 135,026 bytes 510,204 bytes 01:26:28.641 12 1:28:29.804 0:08:26.547 25,640 kbps 35,228 kbps 01:34:51.435 28,579 kbps 01:29:43.586 27,902 kbps 01:35:48.576 133,674 bytes 407,749 bytes 01:36:56.352 13 1:36:56.352 0:10:45.644 25,351 kbps 39,348 kbps 01:37:42.564 30,410 kbps 01:37:00.105 29,627 kbps 01:37:40.729 132,169 bytes 548,047 bytes 01:46:10.989 14 1:47:41.997 0:05:32.290 26,025 kbps 37,186 kbps 01:49:00.951 31,011 kbps 01:48:56.821 30,564 kbps 01:48:59.240 135,682 bytes 472,518 bytes 01:48:56.905 15 1:53:14.287 0:07:52.263 26,047 kbps 39,491 kbps 01:53:41.522 31,021 kbps 01:59:29.787 30,173 kbps 01:59:25.366 135,797 bytes 535,866 bytes 02:01:04.048 16 2:01:06.550 0:11:46.414 22,633 kbps 34,544 kbps 02:02:10.114 31,926 kbps 02:04:32.089 29,899 kbps 02:02:07.945 118,005 bytes 569,057 bytes 02:07:30.726 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 05001.M2TS 4113 (0x1011) 0x1B AVC 114.489 24,413 349,382,520 1,900,438 05001.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 114.489 5,120 73,277,244 416,006 05001.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 114.489 2,757 39,460,936 232,140 05001.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 114.489 2,771 39,659,932 232,596 05001.M2TS 4608 (0x1200) 0x90 PGS eng (English) 114.489 0 70 7 05001.M2TS 4609 (0x1201) 0x90 PGS eng (English) 114.489 0 70 7 05001.M2TS 4610 (0x1202) 0x90 PGS fra (French) 114.489 2 23,081 139 05001.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 114.489 5 65,680 377 05001.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 114.489 2 30,173 178 05001.M2TS 4613 (0x1205) 0x90 PGS eng (English) 114.489 35 507,365 2,849 05002.M2TS 4113 (0x1011) 0x1B AVC 2629.877 25,922 8,521,596,041 46,350,227 05002.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 2629.877 5,986 1,967,651,820 11,103,343 05002.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 2629.877 2,581 848,436,540 5,032,741 05002.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 2629.877 2,540 835,005,160 4,966,565 05002.M2TS 4608 (0x1200) 0x90 PGS eng (English) 2629.877 24 7,854,187 45,090 05002.M2TS 4609 (0x1201) 0x90 PGS eng (English) 2629.877 21 6,940,621 40,679 05002.M2TS 4610 (0x1202) 0x90 PGS fra (French) 2629.877 21 6,936,589 40,034 05002.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 2629.877 21 6,906,679 40,065 05002.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 2629.877 18 6,056,112 35,045 05002.M2TS 4613 (0x1205) 0x90 PGS eng (English) 2629.877 22 7,168,031 40,351 05004.M2TS 4113 (0x1011) 0x1B AVC 60.060 25,823 193,868,718 1,054,472 05004.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 60.060 5,102 38,305,292 217,772 05004.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 60.060 2,946 22,113,588 129,751 05004.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 60.060 2,954 22,176,236 130,513 05004.M2TS 4608 (0x1200) 0x90 PGS eng (English) 60.060 34 255,394 1,477 05004.M2TS 4609 (0x1201) 0x90 PGS eng (English) 60.060 27 205,811 1,238 05004.M2TS 4610 (0x1202) 0x90 PGS fra (French) 60.060 34 255,423 1,479 05004.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 60.060 31 233,341 1,365 05004.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 60.060 28 210,567 1,234 05004.M2TS 4613 (0x1205) 0x90 PGS eng (English) 60.060 11 85,710 480 05005.M2TS 4113 (0x1011) 0x1B AVC 1315.189 25,910 4,259,592,516 23,168,491 05005.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 1315.189 5,954 978,753,624 5,525,227 05005.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 1315.189 2,632 432,651,744 2,559,906 05005.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 1315.189 2,616 430,119,940 2,547,013 05005.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1315.189 28 4,641,553 26,650 05005.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1315.189 25 4,084,078 23,989 05005.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1315.189 25 4,131,060 23,769 05005.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 1315.189 25 4,087,181 23,680 05005.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 1315.189 22 3,591,027 20,848 05005.M2TS 4613 (0x1205) 0x90 PGS eng (English) 1315.189 16 2,638,054 14,805 05007.M2TS 4113 (0x1011) 0x1B AVC 1202.576 25,894 3,892,447,931 21,171,577 05007.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 1202.576 5,504 827,375,740 4,684,405 05007.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 1202.576 2,687 403,947,084 2,386,294 05007.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 1202.576 2,724 409,494,332 2,411,476 05007.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1202.576 26 3,956,242 22,785 05007.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1202.576 22 3,285,695 19,282 05007.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1202.576 26 3,843,306 22,151 05007.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 1202.576 25 3,764,700 21,760 05007.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 1202.576 25 3,749,356 21,669 05007.M2TS 4613 (0x1205) 0x90 PGS eng (English) 1202.576 10 1,434,127 8,064 05008.M2TS 4113 (0x1011) 0x1B AVC 192.067 25,736 617,890,086 3,360,801 05008.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 192.067 5,837 140,137,856 791,851 05008.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 192.067 2,454 58,912,948 350,565 05008.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 192.067 2,496 59,926,208 356,980 05008.M2TS 4608 (0x1200) 0x90 PGS eng (English) 192.067 8 195,714 1,151 05008.M2TS 4609 (0x1201) 0x90 PGS eng (English) 192.067 8 181,028 1,106 05008.M2TS 4610 (0x1202) 0x90 PGS fra (French) 192.067 9 218,699 1,295 05008.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 192.067 10 243,174 1,444 05008.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 192.067 8 184,971 1,096 05008.M2TS 4613 (0x1205) 0x90 PGS eng (English) 192.067 10 231,614 1,301 05010.M2TS 4113 (0x1011) 0x1B AVC 48.173 25,768 155,167,168 843,967 05010.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 48.173 5,674 34,167,448 193,270 05010.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 48.173 2,523 15,189,748 90,631 05010.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 48.173 2,558 15,404,736 91,746 05010.M2TS 4608 (0x1200) 0x90 PGS eng (English) 48.173 21 125,348 723 05010.M2TS 4609 (0x1201) 0x90 PGS eng (English) 48.173 19 111,827 656 05010.M2TS 4610 (0x1202) 0x90 PGS fra (French) 48.173 17 100,047 571 05010.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 48.173 15 89,828 517 05010.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 48.173 15 92,199 535 05010.M2TS 4613 (0x1205) 0x90 PGS eng (English) 48.173 15 88,866 497 05011.M2TS 4113 (0x1011) 0x1B AVC 321.780 25,715 1,034,316,842 5,625,838 05011.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 321.780 5,808 233,607,696 1,319,590 05011.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 321.780 2,444 98,310,764 587,689 05011.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 321.780 2,530 101,781,868 605,943 05011.M2TS 4608 (0x1200) 0x90 PGS eng (English) 321.780 32 1,280,468 7,358 05011.M2TS 4609 (0x1201) 0x90 PGS eng (English) 321.780 27 1,073,858 6,253 05011.M2TS 4610 (0x1202) 0x90 PGS fra (French) 321.780 29 1,162,483 6,702 05011.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 321.780 29 1,155,335 6,738 05011.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 321.780 26 1,034,658 6,022 05011.M2TS 4613 (0x1205) 0x90 PGS eng (English) 321.780 9 359,630 2,023 05013.M2TS 4113 (0x1011) 0x1B AVC 341.383 25,771 1,099,718,542 5,981,534 05013.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 341.383 4,968 211,977,936 1,204,783 05013.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 341.383 2,854 121,806,060 718,269 05013.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 341.383 2,900 123,765,208 725,510 05013.M2TS 4608 (0x1200) 0x90 PGS eng (English) 341.383 24 1,015,041 5,897 05013.M2TS 4609 (0x1201) 0x90 PGS eng (English) 341.383 20 851,584 5,041 05013.M2TS 4610 (0x1202) 0x90 PGS fra (French) 341.383 25 1,061,514 6,154 05013.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 341.383 22 946,399 5,510 05013.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 341.383 23 970,452 5,649 05013.M2TS 4613 (0x1205) 0x90 PGS eng (English) 341.383 7 288,005 1,622 05014.M2TS 4113 (0x1011) 0x1B AVC 1399.148 25,885 4,527,064,708 24,623,410 05014.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 1399.148 6,028 1,054,219,844 5,946,684 05014.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 1399.148 2,600 454,769,188 2,691,304 05014.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 1399.148 2,656 464,547,552 2,748,636 05014.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1399.148 23 4,048,174 23,144 05014.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1399.148 19 3,403,187 19,780 05014.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1399.148 20 3,537,143 20,329 05014.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 1399.148 20 3,473,373 20,086 05014.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 1399.148 18 3,107,318 17,961 05014.M2TS 4613 (0x1205) 0x90 PGS eng (English) 1399.148 13 2,297,936 12,922 05016.M2TS 4113 (0x1011) 0x1B AVC 347.138 18,719 812,273,231 4,419,371 05016.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 347.138 5,764 250,115,828 1,413,463 05016.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 347.138 3,170 137,560,200 803,552 05016.M2TS 4354 (0x1102) 0x86 DTS-HD MA por (Portuguese) 347.138 2,763 119,877,640 708,276 05016.M2TS 4608 (0x1200) 0x90 PGS eng (English) 347.138 0 19,879 114 05016.M2TS 4609 (0x1201) 0x90 PGS eng (English) 347.138 18 785,513 4,525 05016.M2TS 4610 (0x1202) 0x90 PGS fra (French) 347.138 1 53,897 307 05016.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 347.138 1 51,223 293 05016.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 347.138 1 46,587 266 05016.M2TS 4613 (0x1205) 0x90 PGS eng (English) 347.138 2 102,559 577
post #9 of 108
11/28/09 at 6:21am
- Matt_Stevens
- Wrath and Vengeance
- offline
- 13,590 Posts. Joined 5/2001
- Thumbs Up: 20
post #10 of 108
11/28/09 at 8:52am
- Geoff D
- Brockness Monster
- offline
- 1,848 Posts. Joined 3/2007
- Thumbs Up: 17
Gah. Check out the shot of the street corner in post #3. Half of the shop signs have been obliterated.
I dunno if you've seen this one Xylon, but there's a shot of Stansfield arriving outside the DEA building (just before Mathilda goes in to 'clean' him) where the skyscrapers in the distance have been erased from about halfway up by the excessive brightness.
Besson approved the master, and all I can say to that is he needs his ****ing eyes tested. Him and Friedkin make a fine pair.
post #11 of 108
11/28/09 at 9:08am
- Ruined
- offline
- 3,517 Posts. Joined 7/2002
- Thumbs Up: 11
Blu-ray definitely does look better than DVD. And there is definitely detail lost in the Blu-ray due to contrast boosting.
My guess is Besson wanted to "update" the film to make it look more like some of the contrast-heavy films we've seen recently.
Overall though its a big upgrade from the DVD despite the flaws.
BTW, the LFE is also mixed about 10db hotter than typical reference LFE and previous DVDs. It can be very distracting especially in the 40hz and below range.
post #12 of 108
11/28/09 at 9:08am
- lgans316
- Never Ever Warn-her
- offline
- 6,790 Posts. Joined 11/2006
- Thumbs Up: 10
post #13 of 108
11/28/09 at 10:54am
- akademiks
- offline
- 101 Posts. Joined 8/2006
- Thumbs Up: 10
post #14 of 108
11/28/09 at 11:18am
- eric.exe
- Trader Feedback: +1
- Screenshot Engineer
- offline
- 2,305 Posts. Joined 2/2003
- Thumbs Up: 10
Take some pics of any scenes with windows (3:07 for example), whatever was visible in the window is now completely gone in the BD.
No upscale could resolve the grain this well: http://img267.imageshack.us/img267/7...shot054620.png
Contrast aside, I'd say it's a slightly above average transfer detail-wise for a 35mm film.
post #15 of 108
11/28/09 at 1:12pm
- Deviation
- offline
- 2,770 Posts. Joined 10/2006
- Thumbs Up: 13
And again I say that your comments simply have no merit. Yes, there's contrast boosting and yes it's to the detriment of the picture. But saying that it looks like an upscaled DVD is a poor joke at best. The resolution is great and there's seemingly no DNR or EE. If it wasn't for the contrast boosting, this would have been a standout presentation of the film.
post #16 of 108
11/28/09 at 1:17pm
- Kram Sacul
- Screenshot Scientist
- offline
- 5,257 Posts. Joined 9/2003
- Thumbs Up: 10
post #17 of 108
11/28/09 at 2:04pm
- InspectorToschi
- offline
- 308 Posts. Joined 11/2009
- Thumbs Up: 10
I hate the fact that I'll be passing on this Blu-ray. There were 3 DVD versions of the film if I remember correctly, so hopefully we can see a new corrected BD in the future. Don't get me wrong, the BD is quite large a improvement over the DVD (More so then I thought it would be actually) but the boosting is enough for me to pass. I've seen the film too many times and the boosting just doesn't look right. In the first set of Oldman pics, you can clearly see that the grain structure has suffered from from the boost. It's Ghostbusters and Stargate all over again. Though I happily re-bought Stargate because the problems were 100% corrected in the 15th Ann. Edition. But the first Stargate disc helped me learn my a lesson. Therefor I didn't buy Ghostbusters, and I won't be buying this.
post #18 of 108
11/28/09 at 3:57pm
- oink
- offline
- 19,601 Posts. Joined 4/2005
- Thumbs Up: 86
Is anyone else seeing EE here?
post #19 of 108
11/28/09 at 4:02pm
- raoul_duke
- Hyperbole Intolerant
- offline
- 2,261 Posts. Joined 10/2007
- Thumbs Up: 26
post #20 of 108
11/28/09 at 4:13pm
- wyliec2
- offline
- 711 Posts. Joined 2/2002
- Thumbs Up: 11
post #21 of 108
11/28/09 at 4:27pm
- vanilla rice
- offline
- 550 Posts. Joined 12/2002
- Thumbs Up: 10
post #22 of 108
11/28/09 at 5:02pm
- colombianlove41
- offline
- 1,078 Posts. Joined 10/2007
- Thumbs Up: 10
post #23 of 108
11/28/09 at 5:06pm
- Blood Pie
- Amuro Ray wanna-be!
- offline
- 975 Posts. Joined 12/2007
- Thumbs Up: 10
Luc approved this edition so I wouldn't expect a double dip anytime soon.
post #24 of 108
11/28/09 at 5:19pm
- Kram Sacul
- offline
- Thumbs Up: 10
post #25 of 108
11/28/09 at 6:28pm
- SteveMo
- Krissy
- offline
- 3,564 Posts. Joined 8/2002
- Thumbs Up: 10
post #26 of 108
11/28/09 at 9:14pm
- BIG ED
- offline
- 3,280 Posts. Joined 1/2003
- Thumbs Up: 12
vvv
Too me, the fleshtones on the BD look superior & there too much red in the other 2 examples.
How does the SD DVD have better colour timing?
BIG thanks.
post #27 of 108
11/28/09 at 11:18pm
- Deviation
- offline
- Thumbs Up: 13
In this case, the international cut isn't a director's cut... the theatrical cut is what Besson released. The so-called international cut or "version integrale" is referred to by Besson as the "longer version". It adds 23 minutes of footage, most of it character interaction between Mathilda and Leon, including some of the more disturbing relationship scenes and several of the training scenes.
Spoiler
From Wikipedia:
There is also a long version of the film, referred to as "international version" or "version intégrale". It is sometimes called the "Director's Cut" but Besson refers to the original version as the Director's Cut and the new version as "The Long Version". It is also called the "international version" as only this version was released in Japan.[11]
It has approximately 23 minutes of additional footage that was removed from the original release. The additional material is found in the film's second act, and it depicts more of the interactions and relationship between Léon and Mathilda. In one scene, Mathilda plays Russian roulette to try to get Léon to admit he loves her; in another, she openly asks him to be her first lover, but he refuses, although they do innocently share a bed. In another scene he teaches Mathilda the "Ring Trick" which involves knocking on people's door and breaking the chain after the occupant opens the door, and in the event of the occupant fighting back or refusing to open, throwing a grenade inside (when he does, he shows Mathilda the pin). There is also a detailed scene in which Léon teaches Mathilda where to shoot the target, using a cocaine dealer to show her, and how one should never shoot at the face, because doing so would render identification impossible. After he kills the dealer Mathilda burns all the drugs using isopropyl alcohol. He also refers to a past romantic relationship he once had that ended in tragedy and started his career as a hitman. Most of the other material in the longer cut involves Mathilda accompanying Léon on several of his hits, to further her training.
I think most people prefer the longer version, though it's not a universal opinion. It's absolutely worth watching.
post #28 of 108
11/29/09 at 12:14am
- oink
- offline
- Thumbs Up: 86
Spoiler
From Wikipedia:
The longer version primarily focuses on the possible pedophile relationship hinted at in the Theatrical.
There are times when it becomes very uncomfortable to sit through, IMO.
The video and audio is excellent and entirely worth upgrading from DVD (if you are a fan of the film).
I didn't find the "boosted" contrast to be a problem at all.
Thoroughly enjoyed this BD.
BTW, didn't really notice any EE while actually watching the disk.
post #29 of 108
11/29/09 at 1:08am
- oink
- offline
- Thumbs Up: 86
And another thing!
The acting is absolutely top-notch.
It would be hard to find 4 better demonstrations of superior acting in one movie.
Jean Reno - the best I have ever seen him.
Natalie Portman - her 1st role, and her best performance.
Gary Oldman - never topped this.
Danny Aiello - his finest...ever.
Four acting performances of the highest degree.
Without these, the movie would have suffered greatly.
After 15 years, this film's power diminishes not in the slightest.
post #30 of 108
11/29/09 at 2:34am
- BenUK
- offline
- 277 Posts. Joined 8/2009
- Thumbs Up: 10
Back to Forum: Blu-ray Software
- Léon: The Professional comparison *PIX*
AVS Top Picks
Currently, there are 2107 Active Users
(585 Members and 1522 Guests)
Recent Discussions
- › **Official EMP Owner's Thread** 4 seconds ago
- › Official Panasonic VT50 owners thread 29 seconds ago
- › Matte Screen or *really* non-reflective LED or Plasma TVs? (55-65... 38 seconds ago
- › The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] 1 minute ago
- › Fios without renting boxes/cablecard from Verizon 1 minute ago
- › Straight Across or Curved Seating 1 minute ago
- › Advanced MPC-HC Setup Guide 2 minutes ago
- › Samsung un65f7100 vs Sony kdl-70r550a 2 minutes ago
- › Marantz AV8801 Preamp/Processor Official Owner's thread 2 minutes ago
- › Looking for a Blu-Ray player- suggestions please 2 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
View: More Reviews
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
