AVS › AVS Forum › Video Components › Home Theater Computers › fist time in this forum, first htpc component question
post #1 of 4
parts on stand-by
not worried about audio at this time, will be getting a new/low profile 5000 series card sometime soon..when avail.
ASUS M4A785TD-M EVO AM3 AMD 785G $80
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 $80
AMD Athlon II X4 630 Propus 2.8GHz 4 x 512KB L2 Cache AM3 95W Quad $112
LITE-ON Black 4X BD-ROM $50
already got a case, and 1.5 tb hdd. will be used for htpc only with just a front end...will back up my blu rays to system...
any tips or comments.....appreciated... thanks
post #2 of 4
I bought a quad, but if I had it to do over again, I think I'd prefer more clock rate and less cores. jmho. Not to say my quad doesn't work fine, I just think it could work better, and possibly for less money.
Looks good. Get a good quality, quiet, power supply.
post #3 of 4
if you dont need the quad core for encoding tasks then stick with a dual core.
post #4 of 4
will be doing encoding..
thanks for the help
