My Rockin' Room - Page 28
post #811 of 1168
Howdy dd.
... And then I start thinking, hey! I believe the double D owes me a mai tai and some Dungeness crab.
Any time, my friend, any time!!
post #812 of 1168
That's good to know, amigo. As it just so happens, I'll be in your neck of the woods in a couple of weeks. And debauchery is coming with me.
post #813 of 1168
lol, drop me a line...
post #814 of 1168
It was very easy to change, franin. It was like having a brand new pj again. With my dieing lamp I had the iris fully opened and the power set to high. This new lamp was blinding. I closed the iris to -6 and set the power back to normal.
That's good to hear how many years did the last one last you?
post #815 of 1168
Are you ready to let the dogs out?
post #816 of 1168
I got 2 1/2 years and over 2900 hrs out of my original bulb. How many hours do you have on yours so far?
post #817 of 1168
1850hrs. Hopefully im able to get another 1000hrs like you.
post #818 of 1168
I think you should. You've had your pj for what, 2 years now? Maybe even longer. You don't have that many hours on it at all. Keep in mind, I use my pj for everything including tv shows, and sports too.
post #819 of 1168
Did you ever clean the filter? I have to admit that ive only done it once i moved it( the installer did it actually). Apart from that I've neglected doing that job ever after that.
post #820 of 1168
Did you ever clean the filter? I have to admit that ive only done it once i moved it. Apart from that I've neglected doing that job ever after that.
I've only cleaned it once too. When I recently replaced the lamp.
post #821 of 1168
Well I have another 1000 hours left before I clean it. The problem its hard to get too.
post #822 of 1168
You have at least 1000 hours before cleaning duty. Your pj is in it's own separate room. I would think access to it would be pretty easy?
post #823 of 1168
Nope not that easy at all.
post #824 of 1168
Really? I recall seeing it in it's own little house. Seemed to have easy access. I need to bring a ladder in from the garage to change mine.
post #825 of 1168
Don't worry about that need a ladder as well.Its a pain.
post #826 of 1168
I'm jealous because of the star trek poster.
post #827 of 1168
Thanks. I like it too.
post #828 of 1168
I checked mine at 1000 hours and nothing, then at 1600 I had some lint in there and the panel and lamp had a haze on it. After cleaning the pic is sharper and really pops now. Hoping for 3000 hours as well.
By the way Wabo, nice set up!
post #829 of 1168
Hey Caboooooooo! What's happening?
I was pleasantly surprised by how many hours I got out of the original lamp. I think you will have no problem making it to 3000. At about 2000 hours I switched the pj to 'high' mode and had the aperture wide open.
When I reach about 600 hours on this new lamp I'm going to clean the "prism" and the filter again.
In the meantime I'm gonna kick back and enjoy some quality movies. Salud.
post #830 of 1168
Hey Waboman did you get s message at 1900hrs to replace lamp?
post #831 of 1168
Hey, Franin.
I don't think I got the message at 1900 hours. But I'm not 100% certain. I did receive it at 2900 hours though.
post #832 of 1168
Hey, Franin.
I just got it the other day everytime i turned the proj on it was on the centre of the screen. I just replaced the lamp( bought one early last year), it wasnt hard as i thought it would be so im happy about that. Resetting the lamp time was different through the remote.
post #833 of 1168
GET THE CASTERS! GET THE CASTERS!
That said, I've returned for a look at your Synergy. I may be closer to deciding on one of them for myself (despite the size challenges), though likely the a la carte version since it's not as heavy plus that style will better go with the Sanus Euros already in place here.
I know you don't use the rear panels that come with the Synergy, but do they accommodate the cords coming out those back slots pretty well?
post #834 of 1168
"Lol. It's a funny story. Michael Dorn actually signed a very small amount. It was brought to his attention there was a contract dispute and he wasn't getting paid to sign. So he took off (just like a Klingon) . The few he did sign are worth a good chunk o' change."
LOL!
post #835 of 1168
Hit any button and the message goes away. Way cool you had a back up lamp ready to go. Yeah, changing the lamp is really easy. Did you clean the filter too? Lol. It took me a good while to figure out how to reset the lamp time using the remote.
post #836 of 1168
Hey prepress.
Sounds like you're getting closer to getting a new stand. It can be a tough decision. Once in place, it not too easy to pack up and return.
As for the back panels, IIRC, there is a hole in each section for cable management.
post #837 of 1168
LOL!
I know, typical Klingon.
post #838 of 1168
Just received my limited edition 3D Yoda bust. This was a Wondercon exclusive and limited to 1200.
post #839 of 1168
That's awesome!! Yoda never looked so cool.
post #840 of 1168
Hey prepress.
There are nicer racks out there, but the versatility of the Synergy is hard to argue with. The spaces at the top and bottom of the back panel seem as though they'll accommodate whatever cables I put inside that need to run outside. Either walnut or black, with black pillars at this point. Black shows dust too well (and there's plenty of that here), but that might look best with my otherwise all-black system setup.
Is there some sort of cable management system involving the pillars? I though I heard something about that but haven't noticed it on Salamander's website.
