AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Wattage Specs - Receivers
Wattage Specs - Receivers - Page 3
post #61 of 62
The power rating on the back only gives us a max, it doesn't give a clue to the efficiency of the amplifier, or even how much the digital circuitry draws. For instance, DSPs and other internal processors may draw 100W just on their own.
Rule of thumbs are great, but may not apply in all cases.
It's despicable that A/V manufacturers have been allowed to continue to use false advertising to plug their products for years and years. It's not like testing equipment is too expensive. Fact is there's nothing wrong with a 30Wpc receiver. That's plenty of power in many cases, as long as it's well designed, when you consider that the typical loud speaker can generate 90+ dB of sound volume (at 1m) from just 1W. Even when you double that a few times to compensate for listening distance, that's still plenty loud for most people (you guys are not most people).
Years ago I owned a consumer-level Sony receiver that they rated at over 100W per channel, and while it couldn't actually come close, my problem with it wasn't a lack of loudness - my problem was that the thing added a lot of hiss whenever the sound processor was enabled.
post #62 of 62
Originally Posted by DL86 View Post
Usually for any non digital receiver, look at the power consumption of the unit... You will know that if the rated wattage is 7 x 100w and the power consumption is only 300w you can see that, the receiver will never produce the quoted figure. I did hear good stuff about the panasonic digital receivers though regarding power.
One receiver manufacturer I know that is true to their word in power ratings is rotel.
Heh, the back of the pioneer SC-27 list only 330 watts.
But HTM test said it can do over 140w with 5 channels.
Im confused. the back pannel list the total watts the AVR can take. 330 seems way low to me. unless thats for something else?
