Joints don't always have to fall on studding, if the span is small. The framing at the drywall edge will adequately support those panels.
My preference would be the scratch coat be Durabond 45 or 90 (the numbers being working time) with fiberglass tape. Durabond dries concrete like and is an excellent product that greatly reduces any chances of cracking.
The electrical and spot light boxes are poorly cut. But pretty typical and when mudded and sanded, you'll never know they existed.
Some of the upper most small ceiling panels appear to have no framing support at their ends. Those panel ends will rest on the edge of the vertical drywall. It also appears that there's little if any nails near the edges of any ceiling panels. With a subwoofer or two, in the room, personally I'd secure the edges to framing as a precautionary measure.
