Spaceman Theater build - Page 27
post #781 of 1224
I just grabbed one $71.06
Tim
Damn it, why didn't Amazon tell me about this! I have had it sitting in my cart for a year, you think they would have said something
post #782 of 1224
Space, what thickness material did you use to build the arc on your stage?
post #783 of 1224
I used "precurved" 3/8" ply for my stage. Precurved being the warped junk on top that nobody wants. Worked pretty well for me.
post #784 of 1224
Same here.
post #785 of 1224
I used 7/16" OSB, which was running about $8.50/sheet at the time. I believe the plywood equivalent was a little more expensive.
post #786 of 1224
Thanks guys, I'll be making the trip this weekend to HD to work on the arc for the stage.
post #787 of 1224
7/16" was unfortunately one of my delayed purchases. The last I knew it was just under $5 per sheet and I ended up paying $11.49 per sheet just a few weeks ago as the cheapest I could find. D'oh!!
post #788 of 1224
The price of ply and OSB has shot through the roof in the past year. I thought I paid a lot last year when I picked up about 45 sheets of 23/32 OSB but looking now it appears to be about 50% more eek.gif
post #789 of 1224
Yeah, I got hit when buying plywood for the fabric frames. I had budgeted $15/sheet but wound up paying almost $23.
On a bright note, I should have a star ceiling by the end of the day. I haven't purchased black lights yet, so I won't be able to post any pics for a week or two. I'm excited to cross that off the list however.
EDIT: Found a cheap black light at Wally World. See post below.
Edited by Spaceman - 11/30/12 at 10:21pm
post #790 of 1224
Jeff with Night Sky Murals stopped by today for 5 hours and cranked out a star ceiling for me. I only have one 2' black light at the moment so the light levels in these pics aren't the best. Plus I've never shot pictures in the dark before, so bear with me.
One of the 4 small coffers
Same coffer with closeup of the moon
A tad overexposed (4 of the 6 coffers)
Without black light
Same shot with black light. Once I have lights on the sides, the shadow line between the vertical and horizontal faces of the coffer should disappear.
Without black light
The light used is a 24" 17W black light from Lights of America (model 7020 E-BL), picked up at Walmart for $10.97. Unfortunately, they only had 1 and I need at least 6. Haven't quite decided how many sides of each coffer need a light.
Edited by Spaceman - 11/30/12 at 10:22pm
post #791 of 1224
You are truly living up to your namesake Spaceman! Jeff always does nice work and you have to be really stoked. That ceiling is going to be light's out (pun intended) once you get all the black lights installed.
post #792 of 1224
oh wow now i am very jealous i love how your ceiling has turned out.... all that taping off and plastic you went through paid off nicely nice and clean
post #793 of 1224
Omg that is amazing
post #794 of 1224
I'd like opinions on the light pattern in the picture above. For this picture, only one side of the light tray contains a black light. The other 3 sides are empty. By itself, a single light does a fairly good job of charging the stars to the point where I can turn the black light off and have the light level of the stars appear uniform across the coffer (at least on the 3'x3' coffers). I'm struggling with the best approach for when I want to leave the black lights on. Having just 1 fixture in a coffer leaves some funny shadow patterns, especially where vertical drywall meets horizontal drywall.
Like this
Being the cheapskate that I am, I'd like to get by with as few lights as possible. One thought I had was to go with a single bulb in each coffer, placed at the back edge so the light would be visible when entering the front of the room but be behind you when sitting facing the screen. So the pic above would have been taken facing the back wall, with the screen at your back.
Bulb layout would look something like this (6 fixtures, $65.82, 102W). Purple lines represent 2' fixtures up in the tray. My concern with this option is I don't think a single bulb would do a sufficient job on the two 3'x5' coffers.
This pic would be a coffer from Option 1, taken facing the screen.
Option 2 would move the bulbs from the back of each coffer to the sides, allowing me to light the long sides of the 3'x5' coffers. (16 fixtures, $175.52, 272W)
Option 3 pays no attention to my wallet and fills the entire perimeter of each coffer with fixtures. (28 fixtures, $307.16, 476W)
I guess I could order 5 more fixtures and see how option 1 looks. As mentioned before, I don't like the shadow line where vertical meets horizontal, but that won't be noticeable once you're sitting down. I do however, like the way it fades to black as you move away from the light source. A concern I have with Option 3 is there will be so much light, it's just going to look like a big blue box. There will be no fading to black.
As always, thoughts would be appreciated.
Edited by Spaceman - 11/30/12 at 10:36pm
post #795 of 1224
Spaceman, where did you get your L/C/R speakers? Have a link?
post #796 of 1224
I bought them directly from Atlantic Technology when they used to sell their B-Stock on their website. I have a feeling this was cutting into their dealer sales, as I no longer see that as a purchasing option on their website. I also think they discontinued the 727 closed box in-walls. I only see open back in-wall options now. If they don't offer a closed-back model, I'd look at Triad. I went with their in-wall bronze surrounds, which I got from Mike Garrett with AV Science.
Mike Garrett
AV Science Sales 5
585-671-2968
mike@avscience.com
post #797 of 1224
I thought of a 4th option, where the black lights are placed only in the sides of each coffer that are immediately adjacent to the walls. This puts the glow along the edge of the room and lets everything fade to black as you get closer to the center, like a more traditional tray ceiling. Fixture layout would look like this (12 fixtures, $131.64, 204W)
Thoughts?
Edited by Spaceman - 12/1/12 at 4:31am
post #798 of 1224
Not that you would judging by the rest of your theater.
post #799 of 1224
It's tempting. Once carpet is in, it's going to be hard not to just rehang the fabric panels that are done, hang the screen & pj, and call it a day. Who cares if I still have 15 panels to make and the shelves aren't built for the equipment. I will try my best to stay focused.smile.gif
I made a 7am run to 2 of the area Walmarts and grabbed 8 more black lights. I'm going to hit the 3rd store after the boy's basketball games. I was hoping to just order them online, but they are out of stock.
post #800 of 1224
I was able to round up 11 more black lights today. So with the 1 I bought yesterday, there are a total of (12) 24" fixtures up in the trays. They all went in per placement option 4, with the exception of the two coffers closest to the screen wall. Each of those coffers contains 2 fixtures. One runs along the tray closest to the side walls. The 2nd fixture was moved from the tray closest to the screen to the back side of the coffer. Hopefully this will help keep the front two coffers from appearing too bright and becoming a distraction when facing the screen.
Here are a few more shots.
Previous shot under normal lighting conditions
Shot towards screen wall. The fade to black is much more gradual under regular viewing. It gets magnified when photographed.
Shot towards back wall.
Another view towards the back wall, with black lights on.
View towards back wall with black lights off. This picture was taken right after the black lights were turned off, so everything is fully charged. I find the fully charged version to be a little much but the view gets even better as some of the stars start to fade back, creating more of a 3D effect.
Here's a shot of the fixture sitting up in the tray. I'll try to get a better one tomorrow showing the recessed receptacle.
Edited by Spaceman - 12/1/12 at 8:13pm
post #801 of 1224
The ceiling looks amazing. I so wish I had the height to do that, next house if there ever is one. I keep telling myself. Can't wait to see finished pictures, stay focused!
post #802 of 1224
Thank you.
post #803 of 1224
Finally caught up with your build...looks fantastic!
post #804 of 1224
Looks like I missed a few good days....
I personally like option 4. I think mostly since it frames the coffers as a single unit rather than several smaller units. Jeff did a great job.
post #805 of 1224
Thanks guys.
I picked option 4 for the same reason. I liked that it accented the perimeter of the entire ceiling rather than the perimeter of each coffer. I've lived with it for a few days and am still not 100% sure that's the way I'll keep it. I do have some uneven lighting that would benefit from some tweaking. For those using black lights on their ceilings, I'd like to know if you are able to use them during movies or does the screen take on a purple glow like every other white object in the room? Unfortunately, I currently have only one functioning light switch in the room, so I haven't had the opportunity to see how things look with both black lights and can lights on at the same time, or how the black light looks while an image is being projected. I've only seen the black light in a pitch black room, which as we all know, gives every white object in the room a nice purple glow (unpainted walls, primer splatter, t-shirts, etc. My 7 year old proudly dropped trou to show me that his Clone Wars undies glow in the dark). I'm a little concerned about the big white object I'll be hanging in the front of the room and whether it will look purple if the black lights are on during movies, or if the pj and other accent lighting found below soffit level keep the black light from effecting image quality.
If I need to turn the black lights off during movies, I will go ahead and reconfigure the fixtures in the front two coffers so they run along the outside perimeter like the other coffers.
post #806 of 1224
It's been a while since I've been in your thread and boy is your room looking fantastic.
Jeff did a great job on your ceiling.
I personally like your Option 4 as well. I think it will definitly make the night sky look realistic.
I leave my black lights on during movies even when watching them by myself.
I haven't noticed the screen changing hues due to the black lights on. But the true test is when you get your screen in to turn them on without turning on the projector. I think you'll be OK leaving them on.
It allows you to enjoy the ceilind during movies.
post #807 of 1224
Spaceman, your ceiling and the lighting effect is turning out great. The two tone brown colors with the regular lights on is a rich look as well.
Dale
post #808 of 1224
Ceiling looks great Spaceman! The star ceiling might be one of my first upgrades. That assumes I get to a "finished" state in the near future...
post #809 of 1224
Dale
Thanks, Dale. The stars definitely got the wife and kids excited and are a good motivator to wrap this project up so we can all start enjoying it.
It really adds a lot to the room. Going the mural route is a pretty easy upgrade compared to fiber optics, assuming you have a place to hide the black lights.
I'll be mounting the pj as soon as carpet is in. I have a Chief mount with the CM101 ceiling plate (picture below).
Have you guys found black lag screws to use with your mounting hardware or did you paint them black? I need (4) 5/16" x 2-1/2" lag screws to secure the plate to the blocking in my ceiling. Ideally, I'd like to find screws already finished in black so I don't have to paint the heads. Painting is easy enough, but I think the paint would chip off as I ratchet them into the ceiling. Anyone know if black ones can easily be found at HD or Lowe's or should I start looking at some of the specialty fastener places online? I was also thinking of placing a flat washer between the screw head and plate, depending on the size of the hex head. If anyone has a good source for black lag screws, I'd appreciate it. It would save me from running all over town.
post #810 of 1224
Very nice job on the ceiling. Love the look!
