Hello,
I am trying to soundproof a room located next to a master bedroom, especially against low frequencies. There is no direct door between the two.
Would it be better to frame fake walls and ceiling (I have enough room to do so) or just add another layer of 5/8" sheetrock with that green glue at the seams?
If framing fake walls, should I also insulate between the 2x4s with regular insulation?
Thanks in advance!
Thanks in advance!
