Originally Posted by
Mr.G
I thought you owned a AR100U? Are you sure you don't have AC power issues in your home that lead to premature projector problems?
Yeah, I actually decided that I wanted to swap out the ar100 for this LG based on a couple factors, mainly the fact that I just really like the look of LCoS. I have been using an SXRD rptv for the last 6 years and I got used to the crazy pixel density so with the ar100u at 133" from 13' it just wasn't a smooth enough picture for me. I was really happy with the LG up until now. The PQ is amazing and the brightness is more than enough for my room.
I'm not sure about AC power issues in my home but I guess I'll have to consider that. Why would none of my other electronics be affected? I've never had a problem. And this doesn't appear to be a bulb issue at all. The bulb comes on fine and then it just kicks off after 30s-1 minute. It seems like there could be so many different factors at pay here that I couldn't begin to explain why this is happening. Any advice would be appreciated!
