Originally Posted by tacroy
I got my HH66 as a replacement when my HD70 broke. The odd thing is that it looks "softer" than my old HD70 and I'm seeing rainbow like CRAZY and I never did with my HD70.
I've seen somewhere that after 50 hours of use or so rainbows calm down a bit, is that true?
If not, would I be better served spending the extra $300 and moving up to the HD20 even if I only view 720p stuff?
As far as seeing RBE everyone is different. The rainbows should settle down after the bulb breaks in due in part of the bulb dimming. Try turning the brightness down, makes sure brilliant color is turned down low or turned off as this really amps up the brightness. I am lucky as I do not see RBE, even if I try, and know one in my family sees it either. I have seen the HD20 in action, and I personally think the HD66 looks better, maybe due in part to the DC3 chip. Blacks are blacker, and the image is a bit more sharp. Make sure you set your blue ray player to output 720p/60 so the projector won't have to do any scaling.
