Hello everyone!
I tried my first HTPC build based on some posts here and now had some problems on 1080p playback on my new HDTV. If anyone has a similar setup and encountered the same problems I'd love to see how you solved them.
My setup:
AMD Athlon 64x2 5200 2.7Ghz Brisbane 65W CPU
ASUS M3A78-EM Motherboard (780 Chipset, Build-in ATI HD3200)
2x1g Crucial balista DDR-2@800MHz Dual-Channel Memory
WD 750 GB SATA HD
Antec M Fusion Remote 350 Case (with IMon remote)
Windows 7 Professional 32 bit
Panasonic Viera P54S1 Plasma TV
I use the Soundgrah Imon's iMEDIAN HD to organize everything because the windows media center does not play some of my .mkv and .ts files. So far I was able to play most of my files through HDMI connection except the following problems:
1) When I hit the 'Info' button on the TV remote, the TV always says the signal was '1080i' regardless of file type(1080p or 720p or DVD) being played. The Windows resolution is auto-set at 1920x1080 32bit and I don't see why only 1080i.
2) All 1080p mkv and ts files are skipping frames. CPU runs almost 100% when playing this files. Committed memory however never went over 1,000 MB. I am guessing the CPU is a little weak but then many other reported no problem with the 5200 + and M3A78-EM.
I updated drivers for the MB, Graphic, HDMI and HD audio. Also got the lastest version IMon which supports win7 nicely.
Any help will be appreciated!!
My setup:
WD 750 GB SATA HD
And the good thing is the CPU usage suddenly dropped to 20% -40% range while playing 1080p ts files smoothly, which probably means hardware acceleration finally kicked in (which wasn't the case before I forced the 1080p resolution; CPU usage was 80%-100% despite the software always reporting using HW acceleration in both settings).
, this forced mode was not stable! Black screens from time to time and eventually I have to boot in safe mode and cancel this forced mode. What a pity! Look like ATI still got work to do!
