I want to build a home theater system in my bedroom (11.5x10.5ft), but I know very little about home theater systems and such. Could somebody recommend me parts? I'm willing to spend up to $1,000 total (for everything I'd need) - but I don't want absolutely overkill for my not so large room. I will need some wall mountability (even if I have to buy the wall mounts separately).
The source primarily will be a PS3 for Blu Ray and gaming. I was thinking 7.1, but if 5.1 sounds better within the price range, then I'd rather get the better sounding system. I don't want to buy a home theater in a box, because I know these probably aren't the best if you're willing to mix and match parts.
So guys, can you help me out? Home theaters in a box or mix-and-match, I'll do whatever it takes.
EDIT: And I have a question. I'll want to use HDMI right? If I use HDMI from my PS3 to my receiver, and then another HDMI cable from the receiver to my TV, will there be *ANY* input lag?
