I am controlling everything through RF with an MRF-260 if that makes a difference.
1. How can I make the "OFF" button shut off every single component with a single touch?
2. Is there a way to change the volume control from a short burst to a constant on whenever you press the button? I'm having trouble controlling the volume on my Yamaha receiver, I have to keep pushing the button over and over and over just to turn it up a little bit. I think its because it just does a short IR burst rather than blasting the IR continuously as I press the button.
3. When I'm programming macros, I would like all over devices to turn off when I switch between activities. For example, if I'm watching TV and want to change over to a movie, I'd like the cable box to shut off. Is there a way to make the remote turn off whatever else is on when I switch?
4. How can I program discrete codes into this device?
Thanks for the help.
