Last Updated: May 19, 2010
The following table compares the off-air and cable HDTV recorders available for purchase and ownership. These are the only standalone products still available that will record high-definition without a satellite subscription or cable STB/DVR rental fees.
There are satellite DVRs that can receive OTA signals, but those leased DVRs do not function without both a satellite subscription and DVR fee. Cable companies will not activate any other consumer-owned DVRs, aside from those below and the discontinued Sony DHD. The Cisco, Motorola, Pace, and Scientific Atlanta recorders sold on ebay/craigslist will not work on any U.S. cable system.
One SD recorder (Magnavox 2160) is included for comparison.
Tip: When viewing this table, widen your browser window and/or reduce your browser font size.
A more concise comparison of the DTVPal DVR, Moxi, TiVo Premiere, and DirecTV DVR is linked HERE. This is not a comprehensive feature breakdown; it only lists and compares those features that differ between the four products.
Another DVR sold online is the Channel Master CM-7000PAL. This is a rebadged DTVPal DVR with a longer warranty for an extra $100 MSRP.
Notes
* On most cable systems, installing a CableCard allows one to receive digital versions of all cable channels, thus eliminating the need for analog tuners.
* Third tuner is disabled and unusable when a Cisco STA1520 SDV tuning adapter is connected. Moxi does not exhibit this limitation with the Motorola MTR700 tuning adapter.
* Moxi allows recording of one analog channel when the $129 USB analog dongle is connected. The analog dongle is treated as a separate third or fourth tuner, all of which can be used at the same time.
* This capacity assumes use of 2TB external drive.
DISCONTINUED
TRIPLE TUNER
SD Recorder
HD Recorder
HD Recorder
HD Recorder
HD Recorder
HD Recorder
HD Recorder
| INTRO & PRICING | |||||||
| Release date |
Dec 2008
Nov 2009
Dec 2008
Jul 2007
Apr 2010
Apr 2009
Nov 2009
| Price online |
$369 + HDD
| DVR subscription fees required? |
None
None
None
$12.99/mo
or $129/yr
$12.99/mo
or $129/yr
Included
Included
| One-time payment as alternative to fees? |
None
None
None
$299-399
$299-399
Included
Included
| Total upfront cost without any future fees |
$227
$400+
$300
$575
XL: $750
$598-699
XL: $698-$898
$499
$599
| TUNERS |
1
ATSC/QAM/NTSC
2
ATSC/QAM
2
ATSC
2
ATSC/QAM/NTSC
2
ATSC/QAM/NTSC
2
QAM
3
QAM
| SOURCES SUPPORTED | |||||||
| Antenna: Off-air channels |
X
X
X
X
X
| Cable: Analog channels* |
X
X
($129 option)
($129 option)
| Cable: Unencrypted digital SD/HD locals |
X
X
X
X
X
| Cable: Encrypted digital cable channels with CableCard |
X
X
X
X
| Cable: Switched Digital Video compatible (Issues) |
(Requires TA)
(Requires TA)
(Requires TA)
(Requires TA)*
| Separate coax inputs for antenna and cable |
X
X
| BASIC FUNCTIONALITY | |||||||
| Program guide |
X
| High-definition picture with Dolby Digital |
X
X
X
X
X
X
| Pause, instant replay, and rewind on liveTV |
X
X
X
X
X
X
X
| Record X different channels simultaneously |
1
2
2
2
2
2*
3**
| Recording time estimate (built-in) |
33 SD hours
(66 SD w/ SP)
30 HD hours
21 HD hours
XL: 157 HD hours
46 HD hours
XL: 156 HD hours
75 HD hours
75 HD hours
| Recording time with plug-and-play external drive |
300 HD hours*
165 HD hours
XL: 300 HD hours
190 HD hours
XL: 300 HD hours
375 HD hours*
375 HD hours*
| Record scheduling method |
Timers
Timers
Timers
Name-based
Name-based
Name-based
Name-based
| Recorded programs are listed with program title |
X
X
X
X
X
| Watch one channel while you record another |
X
X
X
X
X
X
| Watch a previously recorded program while recording |
X
X
X
X
X
X
| Watch a recording-in-progress from the beginning |
X
X
X
X
X
X
| Remembers where you left off in every recording |
X
X
X
X
X
X
X
| Pause, replay, 30sec skip, slo mo, multiple speeds of FF/RW |
X
(All except slo)
X
X
X
X
X
| Skip 15+ minutes at a time |
X
X
X
X
X
| Play recordings at 0.8 - 1.3x speed with audio |
X
| Progress bar (on trickplay) shows current position in video |
X
X
X
X
X
X
X
| Conflict management |
X
X
X
X
| Record programs it thinks you will like using free space |
X
X
| Set default settings for single and series recordings |
X
X
X
| Correctly handles Daylight Savings Time (DST) changes |
(Manual)
X
X
X
X
X
| Closed captions on recordings |
X
X
X
X
X
X
| PROGRAM INFORMATION | |||||||
| Method of guide data delivery |
antenna
antenna
Internet or phone
Internet or phone
Internet
Internet
| Days of information |
None
Current program
(when available)
8 days
14 days
14 days
14 days
14 days
| Program titles on all channels |
Most locals
X
X
X
X
| Basic program descriptions |
Most locals
X
X
X
X
| Poster images for every program |
X
| Detailed program descriptions, actors, original airdate, new or repeat |
X
X
X
X
| Program information available 24/7/365 |
X
X
X
X
| Program information never goes out for a channel |
X
X
X
X
| No CableCard needed for info on ClearQAM channels |
(Requires CableCard)
X
X
| Source of program information |
PSIP
TVGOS
PSIP as backup
via TiVo servers
Tribune+Rovi
via TiVo servers
via Moxi servers
via Moxi servers
| LIVETV FEATURES | |||||||
| Buffer always active when recorder is on |
X
(Only after pause)
X
X
X
X
X
| Buffer time for pause, replay, rewind on liveTV |
6 hours SD
Unlimited
(One tuner only)
1 hour HD
(One tuner only)
1 hour HD
(30 mins per tuner)
1 hour HD
(30 mins per tuner)
3+ hours HD
(1.5+ hrs per tuner)
4.5+ hours HD
| Number of tuners with independent liveTV buffers |
1
1
1
2
2
2
3
| Swap between multiple tuners without losing buffer or pause position |
X
X
(Loses position)
(Loses position)
| Pause, replay, etc available when recording in background |
X
X
X
X
X
| Buffer is not reset when you change the channel on a tuner |
X
X
| Save entire buffer to a recording |
X
X
| Save buffer for current program to recording |
X
X
X
X
| RECORD FEATURES | |||||||
| Records HD video without quality loss |
(Records in SD)
X
X
X
X
X
X
| Records Dolby Digital 5.1 surround sound |
X
X
X
X
X
X
| Timer-based recording (records using VCR-like timers) |
X
X
X
(User option)
(User option)
| Name-based recording (records and tracks programs by their name) |
X
X
X
X
| Record only new episodes and ignore repeats option |
X
X
X
X
| Custom series recordings to record by user-defined criteria |
X
X
| Series manager to prioritize what is recorded when 3+ programs conflict |
X
X
X
X
| Adjusts schedule automatically when programs change their days, times, and/or lengths |
X
X
X
X
| Programs missed due to conflicts are automatically recorded the next time they air |
X
X
X
X
| Overlap protection to eliminate conflicts when programs overlap by up to 5 minutes |
X
X
| Keeps recorded history to prevent same program from recording twice |
X
X
X
X
| Restrict series recordings to a single timeslot |
(Req manual timer)
(Req manual timer)
X
X
| Start recordings early or end late |
(Schedule edit)
(Schedule edit)
X
X
X
X
X
| Keep only the last X episodes of a show |
X
X
X
X
| Keep each recording "until I delete" or "until space is needed" |
X
X
X
X
X
| Deletes oldest recording (not "keep until I delete") when space req'd for new recording |
(Bugged)
X
X
X
X
| Record from antenna and cable channels simultaneously |
X
X
| Record composite/s-video input |
X
| Edit recorded video |
X
(Only after offload)
| GUIDE FEATURES | |||||||
| Guide implementation |
None
None
Grid / TiVo-style
| Grid-style guide details |
9 channels
3 hrs per channel
8 channels
1.5 hrs per channel
6 channels
3 hrs per channel
6 channels
3 hrs per channel
| Customizable favorites list |
X
X
(Based on usage)
(Based on usage)
| Picture window while browsing guide |
(Overlay)
X
X
X
| Guide genre filters (show only movies, only sports, etc) |
X
X
X
X
| Create recording from program guide selection |
X
X
X
X
X
| View program guide without interrupting recorded playback |
X
X
X
X
| Record indicators for future programs in guide |
X
(Not at release)
X
X
| Permanently delete individual channels from box |
X
X
X
X
X
X
| Displays antenna and cable channels in a single guide |
X
X
| Displays digital and analog cable channels in a single guide |
X
X
(With analog dongle)
| Connects daily to an Internet time server to ensure accurate clock |
X
X
X
X
X
| Navigate through guide 90+ minutes at a time |
X
X
X
X
| Navigate through guide 24 hours at a time |
X
X
X
X
X
| Guide data available for past timeslots |
X
X
| SEARCH FEATURES | |||||||
| Search program titles and descriptions |
X
X
X
X
X
| Search results sorted by name or popularity |
(Name only)
X
X
(Name only)
(Name only)
| Search program titles, descriptions, actors, directors, and categories |
X
X
X
X
| Search with multiple fields and boolean operators (AND/OR/NOT) |
X
X
| Save searches |
X
X
| Record all future matches of a saved search (examples) |
X
X
| Search available VOD titles on Netflix, Amazon, and Blockbuster |
X
X
| DVR UI | |||||||
| High-definition DVR interface (with screenshot) |
Some menus
| Picture window in menus / Can it be hidden or turned off? |
(Most)
No, always on
X
Yes, can be disabled
X
No, always on
X
No, always on
| Number of programs shown on recorded list screen |
6
7
6
8
9
10
10
| Recorded list shows name and date of every recording |
(Only for OTA)
(Name only)
X
X
X
X
| Recorded list can be sorted by name or date |
(Date only)
(Date only)
X
X
X
(Name only)
(Name only)
| Recorded list distinguishes between watched and unwatched programs |
X
| Multiple episodes of same program grouped into folders with episode names and dates |
X
X
X
X
| Play entire folder of recordings, back-to-back with one button press |
X
X
| Single-click delete with Recently Deleted folder and undelete |
X
X
| Record schedule shows names and dates of all upcoming programs |
(Locals only)
X
X
X
X
| Recorded history shows why programs didn't record |
(Limited)
X
X
X
X
| Free disk space estimate |
X
X
X
(Recently Deleted)
X
X
X
| No advertising of any kind |
X
X
X
X
X
| CAPACITY EXPANSION | |||||||
| External drive interface |
USB
eSATA
eSATA
eSATA
eSATA
| Plug-and-play external drive expansion |
Up to 2 TB
Up to 1 TB
Up to 1TB
Up to 6 TB w/ RAID
Up to 6 TB w/ RAID
| Maximum recording time with plug-and-play expansion |
300 HD hours
165 HD hours
300 HD hours on XL
190 HD hours
300 HD hours on XL
375 HD hours (2TB)
1000 HD hours (RAID)
375 HD hours (2TB)
| Interface seamlessly integrates contents of internal and external drives |
X
X
X
X
| Contents of external drive are encrypted and inaccessible to a PC |
X
X
X
X
| Allows unlimited number of interchangeable, plug-and-play drives |
X
X
| Allows internal hard drive upgrades (voids warranty) |
Up to 500 GB
Up to 2 TB
Up to 1 TB
Up to 1.26 TB
Up to 2.1 TB on XL
Up to 2.2 TB
| REMOTE SCHEDULING | |||||||
| Schedule recordings via web and mobile phone |
X
X
X
X
| Real-time conflict management for remote scheduling |
X
X
| Edit and/or delete scheduled recordings online |
X
X
| View list of recorded programs and upcoming recordings online |
X
X
X
X
| PARENTAL CONTROL OPTIONS | |||||||
| Separate, content filtered recorded list for children |
X
(Only in SD UI)
| Require 4-digit PIN to view blocked content |
X
X
X
X
X
| Block certain channels (i.e. require PIN to tune) |
X
X
X
X
X
| Block TV programs at or above certain rating (ex: TV PG) |
(If info available)
X
X
X
X
| Block movies at or above certain rating (ex: R, NC-17) |
(If info available)
X
X
X
X
| Block unrated movies and/or TV programs |
X
X
X
X
X
| Block all programs with specific content (sexual content, violence, etc) |
(If info available)
X
X
| Parental controls temporarily disabled when PIN is entered, and then: |
X
X
X
X
X
| (a) Parental controls re-enable after channel change or recording exit |
X
| (b) Parental controls re-enable after a preset time period |
X
X
| (c) Parental controls re-enable after period of remote inactivity |
X
X
(Uses preset timer)
(Uses preset timer)
| (d) Parental controls re-enable after DVR is set to off/standby |
X
X
(Uses preset timer)
(Uses preset timer)
| Parental controls can be turned off completely (with PIN) |
X
X
X
X
X
| OFFLOAD RECORDINGS | |||||||
| Offload implementation |
SAMBA, FTP
HTTP
HTTP
| Download all recorded files from OTA & unencrypted cable channels |
X
X
X
| Download all recorded files from encrypted cable channels flagged as CCI=0x00 |
X
X
| Download all recorded files from encrypted cable channels flagged as CCI=0x02 | |||||||
| Software to automatically download episodes of favorite series after they record |
X
X
| All recordings downloaded as is, including full HD with DD5.1 |
X
X
X
| View and edit recorded files on a computer |
X
X
X
| Burn recorded files to Blu-ray disk or DVD |
X
X
X
| Transfer recordings to mobile device (iPod, ZuneHD, etc) |
(W/ other software)
X
X
| Transfer HD and SD recorded files from computer back to DVR |
X
X
X
| Format of recorded files |
TS
MPG
TS/MPG
| Network throughput for recorded file downloads |
25Mbps
| MULTI-ROOM FUNCTIONALITY | |||||||
| Multi-room implementation |
Transfers
to other DVRs
Transfers
to other DVRs
Streams
to DVRs or extenders
Streams
| Network throughput for multi-room |
16-24Mbps
70-90Mbps
| Each DVR can send HD recordings to X rooms simultaneously |
1
1
1
2
| Multi-room viewing works with copy protected recordings (ex: HBO) |
(Not at release)
X
X
| Pause a recording in one room and resume it in a another |
X
X
X
X
| Completed recordings can be viewed in another room |
X
X
X
X
| Recordings-in-progress can be viewed in another room |
(Not at release)
X
X
| FF/REW through entire recordings without waiting for transfer |
(Not at release)
X
X
| All DVRs in home can share a single series manager | |||||||
| Recorded programs on multiple DVRs are all combined into a single list |
(Sub menu)
X
X
| Network throughput sufficient to skip all commercials without delay |
Sometimes
Always
Always
Always
| Set-top extenders available to view recorded programs |
X
X
| Set-top extenders can schedule, manage, and delete recordings | |||||||
| Set-top extenders can view EPG and liveTV using DVR's tuners |
X
X
| PC MEDIA | |||||||
| DLNA compliant |
X
(Not at release)
X
X
| DIVX support |
Up to 1080p
(Requires PC)
Up to 1080p
Up to 480p
Up to 480p
| MPEG-4 AVC and VC-1 support |
X
(Not enabled)
X
X
X
X
| WMA Pro 7.1 audio support |
X
X
| Full 1080p output on PC video files |
X
X
X
X
| Browse network shares without PC software |
X
| Transfer PC videos to DVR for viewing |
X
X
X
| Stream PC videos to DVR for viewing |
X
(Limited)
(Limited)
X
X
| Play music stored on computer elsewhere in home |
(DVD only)
X
X
X
X
X
| View pictures stored on computer elsewhere in home |
(DVD only)
X
X
X
X
X
| Play videos, music, or view pictures while recording TV |
(DVD only)
X
X
X
X
| NETWORK CONNECTIVITY | |||||||
| Wired network connection |
100Mbps
100Mbps
100Mbps
100Mbps
100Mbps
100Mbps
| Wireless network connection |
802.11n
(Requires bridge)
($39 option)
($39 option)
(Requires bridge)
(Requires bridge)
X
X
X
X
X
| Download software updates using network connection |
X
X
X
X
X
X
| Ticker bar to show headlines, stock ticker, sports scores on screen |
X
X
| Subscribe to specific RSS video feeds and podcasts |
X
X
| Amazon OnDemand SD/HD with "TV Passes" |
X
X
| Blockbuster OnDemand SD/HD |
X
X
| Roxio CinemaNow |
X
| Vudu OnDemand HD and HDX | |||||||
| Netflix SD/HD streaming |
X
X
SD only
(Requires PC)
SD only
(Requires PC)
| Youtube |
X
X
X
(Requires PC)
(Requires PC)
| CONNECTIONS | |||||||
| HDMI |
v1.1
v1.3
v1.1
v1.1
v1.3
v1.3
v1.3
| Component / S-Video / Composite |
X/X/X
-/-/X
X/-/X
X/X/X
X/-/X
X/X/X
X/X/X
| Maximum native output resolution |
480p
1080p
1080i
1080i
1080p
1080p
1080p
| High-definition output through HDMI and component? |
(HDMI only)
X
X
X
X
X
| Downconverts HD video to SD over s-video and composite |
X
(Composite only)
(Composite only)
X
(Composite only)
X
X
| Native output mode to output all video as is without conversion |
X
X
X
X
| All HD and SD outputs active simultaneously |
X
X
X
| Allows 16:9 anamorphic output through SD connections |
X
X
X
X
| Coax passthrough for TV tuner |
X
(When off)
| Firewire (IEEE 1394) | |||||||
| HARDWARE DETAILS | |||||||
| System chip |
Realtek
RTD1283
STMicro
STi7109
Broadcom
BCM7401
Broadcom
BCM7413
Broadcom
BCM7400
Broadcom
BCM7400
| Processor Details |
Single-core
133MHz(?)
Single-core
400MHz
Single-core
266MHz
Single-core
300MHz
Dual-core
400MHz
Dual-core
350MHz
Dual-core
350MHz
| Graphics Details |
2D only
2D only
2D only
2D only
2D + 3D
(Supports OpenGL)
2D + 3D
(Supports OpenGL)
2D + 3D
(Supports OpenGL)
| System memory |
32 MB (?)
SDRAM
256 MB
DDR400
160 MB
DDR400
256 MB
DDR400
512 MB
DDR2-800
256 MB
DDR2-800
512 MB
DDR2-800
| Hard drive (internal) |
160 GB
(Sold separately)
250 GB
160 GB
1000 GB on XL
320 GB
1000 GB on XL
500 GB
500 GB
| Power consumption |
33W (in use)
20W (in use)
22W
38W
26W
32W
32W
| ENERGY STAR certified |
X
| OTHER | |||||||
| Multistream CableCard slot
A single "M-CARD" supports all tuners with digital cable
X
X
X
X
| Supports wired and wireless USB keyboards |
X
| Requires phone line? Requires Internet connection? |
No
No
No
(Req Internet or phone)
(Req Internet)
(Req Internet)
| Supports cable company OnDemand |
No
No
N/A
No
No
No
No
| Built-in DVD writer |
X
| WARRANTY | |||||||
| Parts warranty |
One year
One year
90 days
One year
One year
One year
One year
| Extended warranty available? |
Walmart.com
2 years for $20
3 years for $29
Sears.com
2yr for $45
TiVo.com
2 years for $30
3 years for $40
TiVo.com
2 years for $30
3 years for $40
| Cost to repair/replace after warranty expires |
$369
$300
$150
$150
$75 + parts cost
$75 + parts cost
| Cost to transfer lifetime service to a replacement DVR |
N/A
N/A
N/A
Free for three years
$199 after three years
N/A
N/A
| SCREENSHOTS | |||||||
| Recorded list | |||||||
| Browse TV | |||||||
| Program guide | |||||||
| Program info | |||||||
| Record schedule | |||||||
| Search | |||||||
| Main menu | |||||||
| Progress bar | |||||||
| Create recording | |||||||
| Record options | |||||||
| Manage/edit programs to record | |||||||
| Network video playback | |||||||
| Multi-room viewing | |||||||
| Offload recordings | |||||||
| VIDEO DEMOS | |||||||
| DISCUSSION THREADS |
Notes
