I had also contemplated trying to put together a more up-to-date version, but I eventually gave up on the idea. As well as requiring extensive research to cover the features of the currently available options, putting together a new table is a formatting nightmare. The easiest way to do it is theoretically to compile a spreadsheet, export it as a series of HTML tables, and then try to convert the HTML into BB code, but since this forum software uses non-standard tags, most of the automatic converters won't work. Perhaps a moderator could make a permissions exception and let whoever creates a replacement topic post the table in HTML (assuming the software is capable of such an allowance), since that would reduce the formatting headaches to some degree. Even so, just updating all the information is quite an undertaking by itself.
