AVS › AVS Forum › Audio › DIY Speakers and Subs › reckhorn b2 and samson s-convert help
post #1 of 13
I just got my reckhorn b2 sub eq. can you tell me if i have it connected right and what exactly do i do with this thing(( sorry I'm so new to this world of audio stuff, but im loving it and want to know more and build more diy subs.
Marantz AVR sr4002 > reckhorn b2 > samson s-convert > ep4000 > Tuba HT
i have my speakers set to small with a LPF/HP @ 80hz. I have my subwoofer out channel set to 0 in the receiver.
what do i set the gain to on my samson-sconvert?
what do i set on my reckhorn b2.
basically is there a principle i should follow regarding setting all the gains and stuff for each little device.
thanks for any help that can be provided. All i really know how to do is build stuff
post #2 of 13
IIRC, you probably won't need the Samson, you can remove it. The B2 can provide up to 12 db of boost. Start with the receiver at 0 db and the Reckhorn settings at 12 o'clock, then adjust the B2's gain and other levels to your listening pleasure. After that the level can be done remotely.
post #3 of 13
since i have a tubaht subwoofer do i want to set the subsonic filter to 20hz?
post #4 of 13
Either the B-2 or the Samson can be removed - they both offer similar level matching functionality. Not sure the SSF on the B-2 is needed for the THT.
I have mine set up so that the amp gain is all the way up and the receiver LFE out is at 0dB. The B-2 handles the gain by itself... in that manner, I can avoid distortion at the receiver's LFE output and still get the most out of the amp.
post #5 of 13
on second thought i have to convert from rca from receiver to xlr on the behringer ep4000 amp, so dont i have to have the samson. i have a behringer ep4000. my tubaht is rated at 500w at 4ohm, but the ep4000 provides way more power than that. if i put my amp gain all the way up am i subjecting to frying my dayton 15 " dvc driver.
post #6 of 13
Yeah, you might not want the amp gain all the way up for that one... I was just saying how it's set up on mine. The IXL needs it that way
I have a QSC RMX-1850HD, currently only one channel in use. I just use the TRS connectors on it to connect to the B-2.
post #7 of 13
I'm in a similar boat . I have recently purchased an S-convert connected to an Ep-2500 with a NAD T-175 pre-pro and only just had the B-1 or B-2 recommended to me. I'm finding it very difficult finding a seller here in Australia (which I don't think there is) unless google is failing me. I placed an order at Creative Solutions and received a reply stating that the unit is not suited to our voltage (240volts 60hz) which is fine as I have a stepdown transformer for 120volt things. Any suggestions to where I can purchase one of these units (B-2)? Other than the one mentioned.
post #8 of 13
not sure, i got mine from creative sounds.
post #9 of 13
No worries. I sent them a reply yesterday saying that I can still use it and go ahead with the sale but I've heard nothing back. Really want the B-2 as it will solve some issues with the bass in my system.
post #10 of 13
I am trying to figure out this same issue but with the b-1
I am very confused about a ton of things and even read I might need both... confused.
post #11 of 13
i finally said screw it and took out the samson s convert. AVR > reckhorn b2 > ep4000. From the reckhorn i just used an rca to xlr cable. Everything still seems to pound and rock the house. It may be wrong, but my ears cant tell a difference. i think the b2 provides everything the samson s convert does as far as gain, but i could be wrong.
post #12 of 13
As far as I can tell, the S-convert is not needed in your setup. The Reckhorn duplicates the preamp function, adds equalization, and adds an adjustable subsonic.
I'd say leave it out.
post #13 of 13
perfect thanks mike. I wasnt sure. it just seem like i had to many dials and knobs and stuff going on for such a simple setup. looks like i should sell the s convert.
