Originally Posted by russ399
I am going to go with 62si's for the rears. Now I'm trying to figure out if the fronts should be si's or clrs. I know that the clrs would match perfectly with the center (clrs), but should't the si's also? Is there anything that using clrs as the fronts would give me that the si's wouldn't?
BTW, I'll be using a sub.
My advice is that if you don't mind the extra size (and cost) of the CLRS then go with those. I have my DV62si's wall mounted with brackets and that would not work with the larger CLRS. In their stock configuration, the clrs does have a more balanced sound. My modded DV62si's are even more balanced than the stock CLRS. One other thing that may be a consideration, the CLRS may present a tougher load to your receiver than the DV62si.
