AVS › AVS Forum › Audio › Speakers › Official BIC Venturi Thread
Official BIC Venturi Thread - Page 16
post #451 of 466
So I've been reading up quite a bit on the Pioneer speakers and they tend to get really great reviews. Does anyone know whether those speakers would be a "jump up" from the Bic Venturi line? Most of the comparison threads I've read on a few different sites and posts say that the Pioneer line wins hands down, and that they actually are superior to many speakers 3-4x the price. Any thoughts?
Edited by butie120 - 2/20/14 at 8:53pm
post #452 of 466
And sorry for the double post!
post #453 of 466
I would say the pioneers are better quality speakers overall. I cant comment on the quality of the components, but they are better balanced speakers. The one area that the BIC's have the advantage is sensitivity. They play much louder with less power, where the pioneers take a bit more power to get loud.
Thats really as much as I can comment.
post #454 of 466
Is the narrow-band frequency response (Hz ~100~10,000) of the DV62si analogous to that of the V52?
Edited by Dom Di Stroia - 3/9/14 at 2:00pm
post #455 of 466
Originally Posted by Dave1027 View Post
Here it is. This is a frequency response comparison of the BIC DV62si. I have three configurations. First is the way it comes stock from BIC. Next is with Ed Frias's mod. Last is my mod. This isn't the exact frequency response of the speaker because it also reflects the response of the microphone I used and my PC sound card. It is however a valid comparison between the three because the exact same conditions apply to all of them. The only thing that changed was the components of the crossover.
Is "dB" the measurement unit of the y-axis of those graphs?
If so, why are the y-axis marker values negative? What are they relative to?
Edited by Dom Di Stroia - 3/13/14 at 9:00am
post #456 of 466
Looks like I'm the first sucker to jump on the D62-3LCRs.
They look nice...nice low profile. I'll give further impressions once I get the other two in...
post #457 of 466
It's the way the software I used at the time displayed it. I'd assume the values are relative to each other.
More important is the fact that this measure gif is 4 years old and is not really valid any more because my mod has seen a few revisions since then that make it even better. I also devised an acoustic damping mod for better bass response.
post #458 of 466
What type of acoustic damping are you referring to?
Doesn't acoustic damping reduce bass response?
post #459 of 466
Proper damping of the cabinet lowers the resonant frequency and increases the effective size of the box. More importantly in this case, it tames the boom. The crossover mod tilts the response toward the bass but the side effect of that was more boom necessitating the damping mod.
post #460 of 466
What method/materials are you using to dampen the speaker cabinet?
Presumably, the crossovers in my Venturi V52's, manufactured in America circa 1992, are superior to the "foreign" crossovers of today. I use a digital equalizer to lower the bass drop-off (rated at Hz ~55~60), but I may be experiencing some of the "boom" that you are referring to.
Edited by Dom Di Stroia - 3/15/14 at 11:28am
post #461 of 466
Your V52s are not the same as the DV62si. It's smaller and uses different drivers. Also the DV62si has nice binding posts. The V52 only has push in spring clips.
post #462 of 466
Looking for specs for the Venturi V10 passive subwoofer - particularly the RMS and peak input power.
If you have them, could you post or attached the specs in your reply?
Thanks in advance.
post #463 of 466
Thanks in advance.
Just to clarify, I assume you are looking for an amp to drive the passive sub, and want to know the max RMS and peak power ratings?
post #464 of 466
I actually have the amp. I'm looking to pick up a used BIC Venturi V10 sub and want to be sure my amp has enough output for the sub.
Thanks for checking.
post #465 of 466
How do you like the D62-3LCR speakers???
Anyone else who has or has heard these speakers can also chime in... I'm looking for a comparison between them and the BIC FH6-LCR speakers. Which is preferred for a mainly HT Blu-Ray Movie setup. Looking at doing 7 of either of these speakers with 2 ID subs for a 7.2 setup.
post #466 of 466
I took a quick look and couldnt find much on the V10 sub. Which amp do you have? Also, how much are you looking to spend and where are you located. There may be better options in the price point you are looking at for a powered sub.
  Back to Forum: Speakers
