Originally Posted by Timothy91
Also remember that you can tinker around with a crossover for ever and ever, but the response graph you get on your test WON'T be the response someone necessarily gets in their room. This is why it's a waste of money to buy a modded crossover and then putting it in a room where it may or may not sound great.
The ONLY reason I would EVER have a custom passive crossover modified would be "IF" I were going to run a very high powered amplifier and needed the speaker to maintain it's intended sound with low distortion. Mainly only needing the inductors swapped out for higher quality ones, as inductors tend to distort with high power. With my 35-watt per channel Pioneer receiver, I seriously doubt I would need a modified passive crossover.
It's true. I did tinker around with the DV62si crossovers forever. It bothered me that I had an otherwise clear sounding speaker but the tonal balance wasn't correct. I knew I could do better. Ed had one point correct that BIC configured the speaker to impress with it's tweeter's high output for home theater purposes. Unfortunately I was using them not for HT but for critical 2 channel music listening. The high frequency output simply made the speakers painful to listen to for any extended period.
The tinkering is over and I now have a speaker that is musical in every aspect. This is what Ed attempted to do. BIC could have done the same. It would have added to the total cost as my mod uses higher quality components, not the price point junk BIC installs. The results are definitely worth it IMO.
While it's true that speakers sound different in different rooms one fact can't be denied. Better sounding speakers always sound better no matter what room you have. This is why higher end speakers are what they are and cost what they cost.
Also about the graphs I posted. I clearly stated those graphs are NOT the actual response of the speakers and that they are affected by microphone and sound card response. The comparison is still valid though. To tell you the truth, the graphs don't really tell the story. The actual difference in tonal balance and sound quality during listening is night and day. Much more drastic than those graphs show. I was surprised when they didn't show a whole lot of difference.
