Hi everyone, I'm about to start the wiring phase of my home theater retrofit.
Here is the problem, the room is roughly 15x16 and the floorplan looks basically like this
The || at the top is the door.
The |------| is a closet
The = is the AV rack
The o are seats and the screen is on the opposite wall.
Now that's out of the way. This room has no attic access to the ceiling. It is on the second floor of the home so the attic space is accessible on the left and right sides as shown above via in wall trap doors, but there is no ceiling access. However there is space above the ceiling just no way to get to it.
I plan to run my wire from the closet wall right behind the AV rack. I'll have speakers on the wall with the couch and where the screen is. As well as a ceiling mounted projector. The only cable I need to the projector is power and HDMI
My main question is can I run cable between the first and second floor between the joists? Or would I be better off going up the closet wall and trying to fish it out of the ceiling from the side access space. I should note the side access space only is about 4 ft high on the interior wall then it narrows to about a 5" gap between the wall of the room and the roof of the house so fishing anything is going to be really blind.
My main concern is to not have to cut up the ceiling and do as little damage as possible.
Any tips?
Sorry for the length, I tried to include as much info as I thought would help.
Code:
A -||---------- A
T | =|------| T
T |o | T
I |o | I
C |o | C
Any tips?
