I recently purchased a Martin Logan Dynamo and ran REW to find the best place for it. I moved it around to a few places and this is the best chart I got:
I don't have much experience interpreting these charts and I wonder if someone can shed some light on the following questions:
1) This subwoofer is not supposed to have much output below 25Hz. However, I calibrated the mic at 75db and the graphic shows around 72db at around 19Hz. Am I reading the chart right? If so, is the subwoofer itself generating those frequencies or is it the room?
2) Since I already played around with subwoofer placement, what other options do I have for dealing with the dip at around 50Hz. Because of the room layout and WAF, corner bass traps are not an option. Would something like GIK 244 bass traps mounted on the ceiling or front wall help there? Or should I just ask Santa for a Behringer Feedback Destroyer?
In general, I'm pleased with this subwoofer. It replaced an AudioSource SW-15, and even though it lacks the slam effect, the new subwoofer is miles ahead in terms of definition. Music sounds so much better than it did with my previous subwoofer.
TIA.
TIA.
