AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Desparate For Onkyo TX-SR507 Assistance Please
post #1 of 10
I don't make a habit out of creating a new thread when there is an owners' thread for this model out there...however, that thread has been lifeless and I am desparate. I have a party tomorrow, and really want to showcase this new entertainment center. I would appreciate any guidance.
I am having a terrible time setting up my new Onkyo 507. I'm running it w/ a PS3 and a DirecTV DVR to my LN52B630. I have 5 speakers and I subwoofer. I ran the Audyssey. When I check my speaker set up it tells me that I don't have rear speakers for 7.1 which is true, but the manual specifically says I can't play some versions of DTS and DD.
Anyhow, I can't get the receiver to play surround or recognize DTS, DD, or TrueHD on the panel. I have it set on (auto), but to no avail...The only time DTS shows on teh front panel is for Neo6, but I don't need that. I have 5.1 speakers. Everything is run through HDMI.
I would appreciate any help. Thank you.
post #2 of 10
Is your blu-ray set to bitstream?
post #3 of 10
I've tried both Bitstream and Linear PCM. I also have trouble with the DVR. Thanks.
post #4 of 10
I didn't realize that I had to use an optical output for the DTS and DD if I only had 5.1 surround. I thought HDMI was good enough. You learn something new every day.
post #5 of 10
Hi, I just found your thread from searching because I was looking for info on the 507. So it's true you have to use toslink to get DTS from your PS3 to receiver?
I was looking to upgrade to the 507 since my current receiver doesn't have HDMI and I was hoping to get away from using the optical cable for sound. I have to assume HDMI does Master Audio since toslink won't.
Hopefully you got your system set up the way you want now, so can you elaborate on the audio for movies, set up?
post #6 of 10
It's rare that satellite and cable TV broadcast in anything other than 2 channel because:
1) Few people use it
2) Takes up too much bandwidth.
Channels like HBO movies in HD are the exception more than the rule. But that would be the best channel to turn to for 5.1 DD
post #7 of 10
The HDMI is good enough. Something is set up wrong in your player.
post #8 of 10
That's what I was hoping. I don't want to have to use optical because if I do, there's no real point in upgrading since that's what I'm using now.
post #9 of 10
Since you are using your PS3 as your BluRay source, its best to go to a ps3 forum and ask the users there, or the gaming & computer sub-forum here.
http://www.avsforum.com/avs-vb/forumdisplay.php?f=94
http://www.avsforum.com/avs-vb/forumdisplay.php?f=26
post #10 of 10
Say what?
Granted you can run in to 2.0 only shows, but most (all?) prime time programming on the major networks is encoded with 5.1. Whether your particular affiliate/provider passes that signal on to you can be a different story. Even in my tiny little DMA, only CBS isn't being delivered with 5.1 via TWC. All of the major cable networks, such as TNT, TBS, USA, ESPN, FX, Discovery, TLC, etc. provide quite a bit of their programming in 5.1. The satellite services are no different.
Sorry, back to your regular 507 discussion. :-)
-Brent
