Hi Gang -
I am trying to complete an abandoned install of the OnQ LyriQ system in my home and have run into a little trouble...
I have everthing working with the Four Source, Eight Zone Distribution Module, meaning when I go to each of my Zones, I am able to select/recieve the 4 different sources with the Audio Keypad Volume Control for each Zone.
My problem occurs when I add a Local Source Input to a Zone. Once this is added, here are the 2 different situations I have:
1) with a local source component plugged in and active, I do hear the audio from this local source component. (good!)
2) with no local source component plugged in, I recieve Source 1 from my 4 Source, Eight Zone Module, but I am no longer able to select/receive Sources 2, 3 or 4. Pushing Source button has not effect. (problem!)
I have gone over my wiring again and again and as far as I can tell, I have it all wired correctly. But, clearly, something is wrong!!
Any suggestion on what my be the issue would be great!
Thanks a bunch!
Cindy
Thanks a bunch!
Cindy
