AVS › AVS Forum › Video Components › Home Theater Computers › Since when is 1920x1080 a relative term? (LCD/ATI/nVidia issue)
post #1 of 47
I read some FAQs and searched around and havent found an answer. Apologies in advance if I just suck at searching.
Background- I have a nice PC in my bedroom with a 9800GT going to a cheap 37" Westinghouse LCD thru DVI and its frikkin perfect. Everything on it looks great, except for the fact that its not a great LCD with crappy contrast ratio, etc.
-SO- I bought a place and decided HTPC and Samsung LCD was the way to go in my Living room. I bought the parts, I built it and I got it all set up in my living room and couldnt wait to see what it would look like. I was excited cause it works so great on my westinghouse.
The mobo I got was a Gigabyte GA-MA785GM-US2H Micro ATX. It has HDMI out and supports sound and video using integrated ATI Radeon video. (Im running win7 enterprise) My Television is a Samsung UN46B8000 LED-LCD (1080p obviously).
So I plug it all in and there are black bars not only on the top of the screen but also on the sides. After consulting Mr. Google, this appears to be a ATI driver issue and there is not a fix for it. Also the text looks like crap. Way better on my westinghouse LCD. The pixelated text is annoying as sin but win7 has a cool custom text size thing that helped a lot. Im still mad that a LCD that cost 4x what my westinghouse one did look so (relatively) awful when a computer gets plugged in. In addition to my rez and clarity woes, there is a judder every 2-3 minutes where it cant quite keep up with 1080p MKV files. It looks like frames are dropping like mad, it lasts about 6 seconds, and it is consistently there every few minutes. Infuriating thing really, pulls you right out of the movie.
Between the rez and the judder, I figure i should have never been lazy and cheap and tried integrated video. In a bit of a rush, I got a 9500GT with the little DVI-HDMI adapter. I installed it yesterday, got it to boot and -epic sigh- 1920x1080 is too BIG for my display. WTF. So ATI is too small and nVidia is too big? Is 1920x1080 not a standard resolution? Why in the HELL do both of my video cards and my TV all have a different idea of what this res is? If anyone can offer me and helpful advice, or a card that is guaranteed to display correctly on my Samsung LED i would love you forever. HALP.
ps- my nvidia card managed to break my sound also, so a card with goood HDMI sound would be cool too, but not the main problem, sound's generally easy to fix.
post #2 of 47
I have no idea what's happening in the first case, but with the nVidia card it sounds like your TV just has some overscan. Go into the settings and change the display mode to 'Just Scan' (I think it's called that.)
post #3 of 47
Hmm, I may go do that. Tho I played around with some settings for 16:9, widescreen 4:3 etc and that all did nothing... I didnt see a setting for overscan tho, I can go check.
post #4 of 47
As for ATI, try to adjust "Scaling Options" (how).
post #5 of 47
Your tv is overscanning on the HDMI input with the NV card. Go to your TV settings menu and look for a dot for dot or just scan setting to turn off overscan to get 1:1 pixel mapping. Be aware that not all TVs support this over HDMI, Check your TV manual. If it doesn't you could try HDMI.
Your ATI was underscanning so you need to set the overscan slider in CCC to 0% (default is 15% for some strange reason). Depending on what version of CCC you have this setting may be hard to find. But it has been posted many times (I posted a solution to this within the last 2 days). Search ATI Overscan and you should find how to do it. All of this presumes you have your desktop resoltion set to 1920x1080.
BB
post #6 of 47
Following on BBs post:
There are many factors that can be causing both your issues (judder and resolution) and they can be TV settings. Your TV does have a native resolution of 1920x1080 so you should be able to get it to properly fill your screen.
1) Go back to the integrated ATI graphics. There is no reason this can't work.
2) Are you connected to the HDMI1 of the TV? This is the only input that supports PC with your TV
3) Make sure your TV is in Screen Fit picture mode. If unavailable, then 16:9.
To possibly help with 24Hz movie judder:
1) Turn off Film Mode
2) Turn off Auto Motion 240Hz (you can try the different level settings as well to see what works best)
3) Turn off edge enhancement
4) Change TV to Standard Picture mode
post #7 of 47
On another note, my Samsung LCD disables overscan/underscan when you label the input "PC". Once I found this setting, it displays bit perfect 1:1 pixel mapping and fits the screen EXACTLY with no need for scan adjustment.
post #8 of 47
BB
I owe you a beer.
Yeah Win7 grabbed a driver automatically and it didnt have CCC. I went out to ATIs site, grabbed the right driver and bam. I feel like an idiot, I'm not some total noob when it comes to this stuff and that sure makes me feel like one.
As far as the judder:
I like the 240hz... its one of the reasons I bought the set that I did.
Its fine for minutes at a time, then it goes stupid. It def feels like a process in the background is causing it. I will run with task manager open and see if something is stealing CPU every few minutes... Any PC based suggestions to fix the judder? Im pretty sure the TV is fine, it doesnt appear to have any problems at all... =\\
you guys are my heroes, seriously. What a helpful forum.
post #9 of 47
The screen judder I was mentioning before, here are some interesting details.
every 3 minutes exactly on the second and lasts 6.5 seconds, then the movie picks back up as smooth as glass for another 2:54... I changed the indexing process to low priority and havent tested yet... what on earth could be causing that... I have a brand new clean win7 OS with nothing but firefox, avg, core avc and mega k-lite... why would my computer flip out for 6 seconds every three minutes? Im soooo close to having my dream setup her, sigh.
post #10 of 47
It sounds like you are having stuttering problems. This can happen if your graphics card can not keep up with load being place on it and is dropping frames. And after it has dropped too many frames it stops (stutters) and catches up with the current content.
Does the audio also stutter? If yes the problem may be with your audio drivers and not your gaphics card/drivers and workload.
post #11 of 47
It could be the 240Hz processing or another post processing the TV is performing, though I usually think they'd make themselves been known by odd motion or artifacts and not freezes. But you should turn them off to verify it isn't the TV causing the issue. 240Hz is really just a selling point and not necessarily something you want, anyway, in all instances.
Some people like post processes - some don't. It tends to mess with the original image and some people don't like the results. It's good for certain applications, though, such as sports or maybe TV shows, but for movies, it tends to ruin the warm, smooth, cool tone of the movie and make it look more like a sharp, high contrast video.
post #12 of 47
Alright Ill give it a shot but I guess Im one of the few who really likes that weird-almost-too-real look that the 240hz leds do. Once you watch enough that the smoothness or clarity isnt distracting its really quite cool. Anyway Ill have some more time to play with it this evening..
oh and to whoever said it should be artificating.. it does, usually for a bit after the stutter then it clears up. -_-
post #13 of 47
I turned off the 240hz and the picture looked nothing like what I bought that TV for =\\ call me a noob or whatever but the crystal clarity and smoothness just disappeared when i turned it off.
however, putting the 240hz setting to 'smooth' from standard took the stutter from ~6 second to closer to ~2 seconds and it still looks good. Im both disappointed and pleased that the problem is in the TV and not the video card. I will find a way to fix it permanently. Further suggestions however, will be much appreciated.
post #14 of 47
I suggest that you try two other tests.
1. Try outputting 1080i to the TV instead of 1080p.
2. Try turning off 240Hz completly.
Other then your PC desktop do you have any other source of 1080p content?
post #15 of 47
Could some re-clocking of the video signal be in order? Maybe this is a timing issue for the signal going to the TV. I think one option is Powerstrip for this.
Peter.
post #16 of 47
You're the majority not the few. That's why the companies place so much emphasis on their post processing technologies and why the display units always have these features turned on.
Me - I prefer to get a TV that supports 24Hz material without resorting to post processing features - not to say your 240Hz TV doesn't. I'm not familiar with the 240hz LED technology, but I do know the 120Hz TV 24Hz support was BS.
One thing to consider, what is the source of your videos? Are they 24Hz movies or 60Hz tv shows? If 24Hz movie, you may be getting this issue because your PC is at 60Hz. So the PC is taking the 24Hz material, doing a 3:2 pulldown, and then passing the signal to your TV at 60Hz and then your TV is trying to work its 'magic' to 240Hz and the 3:2 pulldown is screwing it up.
Try running your PC @ 24Hz refresh for 24Hz movies and see if it helps.
post #17 of 47
- What player are you using?
- What is CPU utilization during playback?
- Is the content local or on the network?
post #18 of 47
jrw...,
Not all HDTVs with 120HZ displays will use 5:5 pulldown or special frame interpolation unique to 24fps in order to display judder free content when receiving 24fps input content.
Many of them just use 3:2 pulldown to convert the 24fps input to 60fps.
Could you please provide more details as to your configuration and testing that led to your statemetn that "but I do know the 120Hz TV 24Hz support was BS"
All digital technology HDTVS do some post processing. AFAIK they never pass the contennt of a an input buffer received from an input connection directly to their display.
The input receives some processing to insue theri are not problems with the content and that the content is complete and is placed in an available output buffer which is then scheduled to go to the display.
post #19 of 47
-Media player classic with mega k-lite and core avc pro
-1080p mkvs keep my AMD Phenom II Black fluctuating around 35-45%
-the content is on a 4TB NAS thru a gigabit switch
Nope it all runs thru a HTPC, no blu ray player except the internal optical drive, which I have not yet tested (im not big on discs, lol)
okay, Im at work now, itll have to wait till later tonight..
forgive my ignorance but lolwut?
Thanks for all the posts so far, you guys rock!
post #20 of 47
ps- can someone shoot me a link for a discussion on getting my realtek hdmi out to send the 5.1 audio that I know is encoded in the majority of these files I have? it only sends two channel stereo and I would really like to get that working. I dont know where to start troubleshootign and I dont wanna start another thread. I figure now that some smart people are already subscribed to this one I should ask here. I cant be the first one to ask this question... tia
post #21 of 47
You might want to try uninstalling CoreAVC and k-lite. MPC-HC has all of the necessary filters to playback almost anything.
Assuming that the MKVs you are playing contain h.264 or VC-1 you should get very good hardware acceleration (HWA) using ATI graphics w/ the MPC-HC video decoder.
That seems really high for HWA to be working (see above).
Have you tried copying a file locally and seeing if the issue repros?
You have plenty of bandwidth there, if the issue doesn't repro w/ local playback check NIC drivers (latest is usually best, but not always) and utilization on the NAS (if possible).
post #22 of 47
thanks for the suggestions, as soon as I get home from work Ill get started and try some stuff out! I really appreciate it
post #23 of 47
I should of said many, especially generic LCD 120Hz. Obviously there are higher end LCD 120Hz TVs that properly handle 24Hz. They're BS in the fact that to get 120Hz, it's just doubling 60Hz. So with 24Hz material, it's still having 3:2 pulldown to 60Hz and then just doubled to 120Hz. You have to be careful that your TV actually natively supports the refresh rate it mentions or if it's 'acheiving' that refresh rate through processing of a lower refresh rate, which is obviously fine for 60Hz material but screws you with 24Hz material.
post #24 of 47
Following is a link that descrbes how the Vizio 120Hz models can handle 24fps input content.
You can have it do 5:5 pulldown instead so as to eliminate Judder since all frames are displayed the same number of times.
http://www.hometheatermag.com/flat-p...420m_lcd_hdtv/
post #25 of 47
AH HA! Success!
The judder problem was happening for 5 seconds every three minutes. I couldnt for the life of me figure out wtf was going on. That is until my friend saw my PC and went WOW THE BACKGROUND CHANGES AUTOMATICALLY? (win7) And I went yeah, I set it to change...every...three.. minutes.... OMG. I'm an idiot. I should have thought of this ages ago, I just didnt think that a picture changing could use so much processor that it would judder my video for 6 seconds straight, I got a nice dual core proc =\\ . Anyway - I changed the desktop and voila! no more judder, just some basic artifacting that I will try to fix. So now I am on to the challenge of trying to output 5.1 audio. Any basic FAQs or links?
post #26 of 47
DD/DTS 5.1 audio is pretty simple these days. Bitstreaming TrueHD/DTS-MA found on blurays is a little more challenging.
Are you using a receiver? Does it support HDMI or SPDIF toslink/coaxial? If no receiver, how do you plan on connecting speakers to your PC?
post #27 of 47
How do you accomplish this? I am still having a slight underscan problem with my setup.
post #28 of 47
Keep in mind two areas can cause overscan/underscan issues. Your TV and your PC. Make sure your video drivers are set to 0 and make sure your TV is set to its 1:1 option for picture mode. Each manufacturer calls it something different.
Changing the Input name to PC didn't resolve the issue so much as when it was changed to PC the TV defaulted to the picture mode of 1:1, but you can get to this from any named HDMI input by changing the picture mode.
To set 'PC' as the named input, go to the menu and then inputs. Select the input that your PC is connected to and then you should be given a list of names to choose. Scroll to PC and select it.
post #29 of 47
I have a Sony ht-is100 receiver/sub combo with HDMI and fiber connections. Im currently running audio and video over HDMI to the receiver from the pc. It says 2.0 Channel on the receiver even when Im running mkvs thats I know are encoded to have 5.1 audio. Its like the soundcard isnt putting out the right format. I have the realtek HDMI audio driver and Im just not sure where to look to fix this. I could probably troubleshoot it but Im short on time these days and if anyone has suggestions I'd love to hear em. It might be a simple setting somewhere in MPC or the Realtek control panel but I cant find it for the life of me.
tia
post #30 of 47
Sounds like you may have the sound card options set to not 'pass through' DD/DTS but decode it instead. It could also be a setting in your playback software where you don't have it set to pass through, either, and it's decoding DD/DTS. At some point, your PC is being told to decode a DD/DTS stream and reprocess as 2.1 PCM.
HOw are you passing audio to the 9800 over HDMI? SPDIF connector? If so, we'd need to know the model of your dell MB to determine if the on-board audio supports 5.1 pass through.
