I am thinking about buying that $79 Magnavox blu-ray player from Walmart as an extra BR player for a tv and other house but I am kind of unsure of the quality so I would most likely get the Walmart warranty. How does it work if the unit is a piece of junk and in a few months will not play movies and so on? Will they fix it (I don't know how if there is no FW update), replace it and with what if the same model is no longer available?
In-store Warranties and repair/replacement
AVS Top Picks
Pros:“Excellent value for the price - Paid $79.95 at Frys.”“Absolutely stunning 24p play back. Networked Apps are flawless (wired). Very customizable. Unbelievable DLNA capability. Ability to skip the unskippables in a DVD. Overall professional onscreen GUI. Audio Quality is surprisingly very good. Upscaling as a customizable, menu driven item. Very Apple-esque.”
