I dont know if this is allowed here(otherwise remove it)
This Thread is for Enable the usb port to watch mkv and xvid HD.
Be Aware this hack/trick is on your own risk and only for europe LH/LF and some LU models only.
Press menu on remote and go to options but don't press ok, now press 7 times on the fav button now a screen apears with Software update (Expert) download version v03.15.00(not needed if you already have v3.15) and put it on a usb stick now the TV will see the file press ok and it wil downgrade or upgrade to v03.15.00.
Now The Service menu works again.
To acces Servicemenu press ok + ok for 5sec and a pw screen apears pw=0000(this you need to enable usb and xvid-mkv playback), go to option number 3 and set jpeg,mp3 to 1 and divx/xvid to HD.
For in-start (servicemenu)use the menu + menu buttons also 5sec and a pw screen apears pw=0000, Real servicemenu dont use this.
So here is now mkv and xvid enabled on my 37LF2500
Firmware Updates:
V3.15 http://devil-strike.host22.com/LG_DTV_v3.15.zip
Changelog:
1. Add Divx information in Simple Manual in LH5000
2. After downloading bar-code, EDID checksum was changed - Fixed EDID
3. If there is movement for LCN, LCN changed automatically - Auto/Manual Tuning Duplicate
V3.37 http://devil-strike.host22.com/LG_DTV_v3.37.zip
Changelog:
1. S/W Upd for MP 1'st of 42/47LH9000, 32/37/42/47SL8000, 42LF2510, 32LF5100 IF there are some Ass'y already worked with previous version , those thing should be reworked at LGEWR
V3.40 http://devil-strike.host22.com/LG_DTV_v3.40.rar
Changelog:
1. Nand Flash S/W Update V3.40.00 for all GP DVB EU Model Series as running change.
2. Standarization of S/W vrsion.
3. Field Claim from Austria - Channel map disappearance issu
V3.55 http://members.chello.nl/devilstrike/LG_DTV_v3.55.zip Mirror: http://devil-strike.host22.com/LG_DTV_v3.55.zip
Changelog:
1. Spain CI issue
2. HDMI tact time reduction
3. Germany Mux Skip issue
V3.63 http://members.chello.nl/devilstrike/LG_DTV_v3.63.zip Mirror: http://devil-strike.host22.com/LG_DTV_v3.63.zip
Changelog:
1. S/W willl solve language problem in LGEBN
2. Update Nand Flash of GP EU All model as running change.
V3.65 http://members.chello.nl/devilstrike/LG_DTV_v3.65.zip Mirror: http://devil-strike.host22.com/LG_DTV_v3.65.zip
Changelog:
1. Spain TDT Certification: Audio descriptor GLG Multilan notation for incident response should not apply. Russia- error response string
2. No signal problems during connecting CI CAM
3. Tuner PLL IC Device ID detect change
4. ATV problems HP improvement in the input
v3.66 http://members.chello.nl/devilstrike/LG_DTV_v3.66.zip Mirror: http://devil-strike.square7.ch/LG_Fi..._DTV_v3.66.zip
Changelog:
1. When some specific JPEG photo is dispayed via USB , TV cannot display normal image due to NR(noise reduction)'s function error.
v3.67 http://members.chello.nl/devilstrike/LG_DTV_v3.67.zip Mirror: http://devil-strike.square7.ch/LG_Fi..._DTV_v3.67.zip
Changelog:
Updating Nand Flash of GP EU All model as running change YES
1. Under Russia specific CAM envirnment , when channel change ,TV state goes to NO-SIGNAL
2. Add Slovenia certification LOGO in E-streamer
3. When input change to USB photo , NR did not change with previous NR data
4. Passwd changed from 0000 to 0413 entering to service menu
5. Under USB photo data envirnment , some JPEG pattern did not printed. ? RSVOC
6. Under NVM uninitialized envirnment(only first power on) , during AC power on TV set getting LatchUP and reset. But after reset , it?s OK.
v3.68, Found on ld320 models builded in sep 2010, but need epk file(not found yet)
On v3.66 Firmware, the password of the service menu's are changed fron 0000 to 0413.
Firmware only for this models listed below, dont flash it if your tv is not listed.
32LF2500 37LF2500 42LF2500
19LH2000 22LH2000 26LH2000 32LH2000 37LH2000 42LH2000
32LH3000 37LH3000 42LH3000 47LH3000
32LH4000 37LH4000 42LH4000 47LH4000
32LH5000 37LH5000 42LH5000 47LH5000
32LH7000 37LH7000 42LH7000 47LH7000
19LU4000 22LU4000 26LU4000
19LU5000 22LU5000 26LU5000
Dont flash it on CANADA/USA/ASIA/AUSTRALION TV SETS
Wiki: lgusb.wikispaces.com
Remote codes:
Compatible LG TV :
19LH2000 22LH2000 26LH2000 32LH2000 37LH2000 42LH2000 32LH3000 37LH3000 42LH3000 47LH3000 32LH4000 37LH4000 42LH4000 47LH4000
32LH5000 37LH5000 42LH5000 47LH5000 32LH7000 37LH7000 42LH7000 47LH7000
19LU4000 22LU4000 26LU4000 19LU5000 22LU5000 26LU5000
« EZ Adjust » compatible remotes :
Tevion MD 81302 - Code 0119 - press EPG
Philips SRU7140 - Code 0119 - press INFO
Thomson ROC2407 - Code 0119 - press [SETUP] then [--/-]
Total Control 8 in 1 - Code 0119 - press [SETUP] then [--/-]
SilverCrest DT33137 (URC101) - Code 0119 - press [SETUP] then [--/-]
Philips Pronto RU950 or TSU3000 - 900A 006D 0000 0001 04FB FF00 - Code 255 = "EZ Adjust"
RCA universal remote :
RCA RCR3273N RCR3283N RCR412SN RCR412BN RCR4383N RCR4258N RCR4358N RCR4373N RCR4383N RCR461 RCR612N RCR473N RCR812N RCR815N
code to program : 11265
Press the GUIDE button
Meliconi Fully 8 ou GumBody : Program LG xxLF/LH/LUxxxx = 98000142164260
Program code EZ menu ADJUST = 255.
Instructions to program remotes :
cme.it/meli2/help1.php?idm=fr&mtm=a8
cme.it/meli2/help13.php?idm=fr&mtm=c1
1°) Press 5 seconds on "TV" (red light blinks) : insert cod 98000142164260
2°) Press 3 seconds on "TV" + "OK" and enter code 255
Logitech Harmony 555 :
- Add LG TV in Harmony remote configuration
- Connect to Logitech Harmony website with Login/Password : http:// members.harmonyremote.com
- Go to : http:// members.harmonyremote.com/EasyZapper/Infrared/ShowInf¬rared.asp
- Click on "Manual >"
- In "Data Value" zone, copy/paste this Philips Pronto code :
0000 006d 0022 0002 0157 00ac 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0689 0157 0056 0015 0e94
- Click on "Process >" : message "Converted from Pronto format successfully!"
- Click on "Next >"
- Click on "Select an active device"
- Choose device for your LG "TV"
- Enter command name "EZ Adjust", for example
- Click on "Add >"
In remote software, you can now assign command "EZ Adjust" to any button.
Thnx Ptit_Philou.
Firmware Updates:
Changelog:
Changelog:
Changelog:
Changelog:
1. Spain CI issue
Changelog:
Changelog:
Changelog:
Changelog:
Remote codes:
Compatible LG TV :
- Click on "Next >"
- Click on "Add >"
Thnx Ptit_Philou.
