AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Firmware Hack And Firmware updates LG LH/LF Series
Firmware Hack And Firmware updates LG LH/LF Series - Page 17
post #481 of 697
Originally Posted by Georgie3 View Post
And the TV being from the world of Linux & open source has no idea about proprietary formats like WMV and DTS G
I knew it can't handle DTS but I remember reading on another site (similar to this) that people with a larger 2009 European model were able to play WMV files. Seems the European models can do a lot of things ours can't.
post #482 of 697
Remote just came! MPEG-2 MPG files play perfectly with no menu corruption at all. As soon as I hover over an MPEG-4 and the player tries to 'preview' it, that's when the menu corruption happens. The files I tried were all anamorphic and all played fine. What kind of aspect ratio problems are you having?
What is the advantage in using MPEG-2 TS rather than MPEG-2 MPG? I ask this because I have a program that will convert to MPEG-2 MPG easily, rather than having to do all of that stuff you listed for the MPEG-2 TS. So, if there's no difference, I'll stick with the program. If there's a big difference, I'll change it up.
EDIT: Also, very important... The files all seem to play with TruMotion turned on, even though I have it disabled for all inputs. Does this happen to you? Do you know how to disable it for USB playback? I'm guessing that the 'Picture Settings' are disabled for my firmware for DivX HD playback. That sucks. It almost renders it completely useless. I wonder if upgrading the firmware will bring back Picture Settings or if it will make things worse.
post #483 of 697
Hi... I seem to need .ts format to get 16:9 aspect ratio to work right for some movies, and stability is better. With .mpg it tends to quit playback very occasionally. I do use .mpg sometimes, if .mpg works for you then go for it. By the way you can convert back and forth easily - .mpg to .ts using tsMuxerGui, and .ts to .mpg using MPEG_Streamclip.
The limited options in changing picture settings is a pain, and as far as I know applies to all sets European or North American (maybe the 2010 models are better). Here's what you can do:
- The quick AV settings work to change between presets, so choose which one looks best. Unfortunately TruMotion is on for all of them on my set. With 1080p movie playback I hardly if ever see motion artifacts, I find it's more noticeable on lower resolutions.
- Use energy saver to adjust brightness
take care,
G
post #484 of 697
take care,
G
Man, you are the best! Switching it to GAME turns off TruMotion! Cinema and Sport still have it on, but Game mode does not! Game mode doesn't look TOO bad, either (just a tad darker than I'd like, but whatever, it's better than TruMotion). I tried using TS instead of MPG and it seems to look just as great. You are a life saver. Double check with your set to see if Game mode has TruMotion because it definitely does NOT on mine. I've tested 6 videos so far just to be sure.
My program seems to convert files faster to TS than MPG, as well. Took me 15 minutes to convert a 1.34 GB 2 hour film from MPEG-4 AVI to MPEG-2 TS. Not bad at all.
post #485 of 697
Sorry for the late reply.
My tv is the LG 42LH2000 and it plays everything except MKV with DTS.
My friends tv is the LG 37LG5000 , i have been able to use the IR hack and get a service menu up on screen but this menu only has options for the HDMI/RGB inputs along with a couple of other options and a TOOL 1 menu , there are no other options available. His firmware is v 3.35.1.
Are there any firmware versions for his model that allow usb playback ?
Scouse
post #486 of 697
Scouse
DTS is not supported only mkv with ac3 and or other formats with ac3 only.
post #487 of 697
I know i convert the audio track and it plays fine
post #488 of 697
I am little confused because I have the model 32LH70YR, and the only thing close that i've seen here is 32LH7000. Does anyone know if my TV can do the upgrade. I purchased it a few months ago, and it won't play mkv files. Also my display is a little blurry when I'm using HDMI and I thought a firmware fix might help.
Omer
post #489 of 697
Hi Guys!
For srt problems I found (with mkv too), load srt filr into Subtitle workshop and save in the same format, it will work.
I usually make longer duration time and upper case for better watch on the creen.
post #490 of 697
Hi my friends.
I have a 42lh30fr with fw 3.20 and would like to have it accept mkv, hd through USB port, I also have a gain in legends, why are very small, which fw should I install and where to find? Grateful.
post #491 of 697
Hi everybody, hope someone can help. I'd like to connect my Android phone to the LG tv I already hacked. I'm just not confident trying it before someone confirms it won't short circuit my phone or anything!
I guess for it to act as a usb memory I just need to enable the UMS option... but will the tv be fine with it?
post #492 of 697
Originally Posted by KCO.CL View Post
If the same case, in menu Ez Adjust I get the following:
I was thinking about changing the European firmware v3.15 by serial port...
Bad news.
I've the 32LH70YR and the same EZ-Adjust screen. The OK-OK or Menu-Menu method doesn't work.
The TV is based on the LP91A chassis and use the LGE3767A (based on the MST99A88ML), the legend on the schematics say "MATRIX ONLY SD DIVX_NON RM" and this chip is certified by DivX as "DivX Home Theater Version 3.0 (720x576)" so the equipment based on LP91A clearly don't play HD DivX.
Code:
http://rapidshare.com/files/430506248/sm_lg32lh70yr.djvu
post #493 of 697
Hi.
I activated succesful the usb-port on my tv thanks to the tutorial on the forum.
But i was wonder if i could activate other settings too or not.
This is the results: (these settings are safe and tested and working)
Ez-Adjust
Tool Option 3:
EMF(JPEG,MP3) - 1
Divx - HD
Bluetooth - 1
Digital Eye - 1
Tool Option 4: THX - 1
THX Media Director - 1
Picture Wizard - 1
P.S. - I have pictures too, but I cant post now, because this is my first post.. In PM i couls send the link...
post #494 of 697
Originally Posted by tomohawk View Post
Hi.
Ez-Adjust
Tool Option 3:
EMF(JPEG,MP3) - 1
Divx - HD
Bluetooth - 1
Digital Eye - 1
Picture Wizard - 1
I would stay away from the other stuff. I've heard about people bricking their set for activating things like Bluetooth when their TV doesn't come with Bluetooth, etc. I even saw some THX modes in the menus but I chose not to activate it for 2 reasons:
1) I rather love how my TV is calibrated, so I doubt I'd switch even if the THX mode looked nice.
2) I don't think that *my* particular display was THX calibrated - I think that it's just part of the general firmware, so it's not going to help by enabling it unless this model's panel were calibrated.
post #495 of 697
Hello everyone,
I read about the method for USB activation, however my TV set doesn't have
diagnostic screen. When I enter SETUP menu there is no diagnostic submenu to check fw version for the start.
model is 42LF2510
Thanx in advance
post #496 of 697
Originally Posted by qaswed View Post
Hello everyone,
model is 42LF2510
Thanx in advance
It is Menu->config->Diagnostics
post #497 of 697
hello
i exedently press W/B Reset under W/B cool values
can you help me restore them back?
my tv model is LG 37LH70YR
post #498 of 697
hello
post #499 of 697
Hello, i wasnt sure if post here but couldnt find info about this no where else...
I have a LG 42LH30FR made in korea on may 2009, it has a USB that can be use to watch DIVX, i dont care about that because y have onother device that does this.
The problem i have is the following, My brother has a LG 42LH30 made in mexico feb 2010 has a function to turn on the tv at the time I set , on the source i set, but mine has this very limited, i cant set any source , just on tv channels (no video or com or hdmi), i couldn find what version he has but mine has 3.09, im guessing that with an update mine will also get those function (maybe more), but i havent found any update for it, i found for other tvs in lgusb.wikispaces and some other websites, can some one guide me please
post #500 of 697
What is "digital eye" anyway? Is it the sensor that changes the screen birghtness according to ambient light?
My model doesn't have it so I would be careful with such options.
post #501 of 697
Originally Posted by tuvia_1 View Post
hello
This values aren't absolute, depends on the system. Maybe my values don't match your TV.
Temp: Cool
RGain: 174
GGain: 141
BGain: 192
ROffset: 128
GOffset:128
BOffset:128
post #502 of 697
What s happened with lgusb.wikispaces.com
post #503 of 697
Hi all,
is there any possibility to get in to TV Link-loader menu (Hotel Menu)?
I have 42LF2510. Updated to v3.67 and unlocked USB. I have access to EZ Setup (Tool Option 1,2, etc.) menu via Emtec universal remote.
But how to get to other "service" menu (Hotel Menu) and TV Link Loader. I want to download TTL list from my TV to USB stick like i Did in v3.15.
I also have RSR232 Null-modem cable. Can i use it to get into Hotel Menu?
post #504 of 697
Hi there, I'm/was the author of http://lgusb.wikispaces.com the wiki that got deleted by WikiSpaces.
The wiki was deleted after wikispaces got a DMCA notice from LG's lawyers.
Here's what they said :
We received a DMCA notice from Ross Panko the attorney of LG Electronics, Inc. (contact details below) indicating that information hosted on your wiki infringes on LG's copyright. The wiki in question is
http://lgusb.wikispaces.com/
According to his claim, the wiki is providing information purporting to instruct others on how to circumvent the security technology contained in LG's television products.
We have removed the deleted your wiki.
I'm saddened and wondering what they mean with "circumventing the security technology" when all that wiki was about was a simple click of some buttons....
It's sad to see that page remove but I guess there's not much that I/we can do about it.
I have a .pdf version of the wiki, that I could upload it somewhere if people are still interested in the information it contains.
Unfortunately you will have to search for the firmware files as I saved only the frontpage.
P.S. Thanks to everyone! I'm still amazed by the response and interest that the wiki generated.
post #505 of 697
HI Jeton.
I am jenya from lg-hack.info. My wiki about hacking LG TV on openlgtv.sourceforge.net was closed on DMCA request from LG too.
But We already have new wiki hosted outside DMCA effect
If you still interest in contributing LG USB hack wiki - write to me (i send contacts via private message)
Regards.
PS: by the way - all yours wiki content still available from google cache.
post #506 of 697
Originally Posted by jenya View Post
HI Jeton.
Regards.
**** LG witch copyright? we dont do anything wrong, Firmwares and the hacks are legal the only problem is warranty.
Before avs closes this forum i will make a backup of my startpost.
post #507 of 697
is firmware 3.67 still latest one or there's newer one?I have 42LH5000 with firmware 3.67 on it so I was wondering is there anything newer? thanks...
post #508 of 697
I wish to thanks to all who shared here the info about activating usb on lg tvs especially to Devil Strike,Jeton,Georgie and to all of you for risking your lcd(in the name of the science :-)) .
After reading here all posts I have decided to try (risk)this on my 26LH2000 LG with fw 3.47
I first upgraded to v 3.65(EU_ALL_0.1.57.66_flash.epk) than down to 3.15,activated what described Devil Strike on first post than upgraded again to 3.65.
Somewhere I found this LG pdf manual and I try to attach here if permitted
If they are doing this like in the manual,why don't we?
works great for me!
Thanks again!
If someone needs the fw files that I used,send me pm with your email,
Danny
GP USB Download Manual.pdf 159.2646484375k . file
post #509 of 697
Hello Jeton,
Bad news everybody. Jeton, can you please upload that .pdf file to megaupload.com?
I am trying to use ir hack, installed irremote, and i have a file called LG__33700.ir but I dont seem to be able to install it.
post #510 of 697
Hi,
I bought 32lh3000 and i unlocked USB port like you described without any problem.But i have a problem with playing movie from usb with this specifications:
Runtime ..: 02:41:42
Size .....: 10.9gb
Video ....: 1920x1080 (X264 @ 23.976fps)
Bitrate ..: ~8171kbps
Audio ....: DTS 1509kbps
Picture is awesome but there is no sound(it says "unsupported audio").Is this have anything with audio format "DTS"?
