And in searching for that, make sure that no setting changes are inadverantly made. Coz they get saved without warning when you exit out of the FW pages. Btw check out the wiki site discussions @
http://lgusb.wikispaces.com/: some guy has found a hack to get the "DivX" option to appear in the menu.
Originally Posted by
Georgie3
Sorry, looks like your menus are different. Unless you can find something called "DivX" in another place you may be out of luck.
G
@ long_pn
For your Asian model try this first.....
"LCD TV 32LF20/Аsia-model/
Firmware 4.04
Goto into service menu (press Menu on both Remote Control & TV at the same time until password screen popup then enter "0000" as a password)
Tools Option 2 & Enable USB. That's it.
You will see the USB on the menu now..Enjoy!!"
.......Enable USB means make it = 1. So that means nothng to do with 'Tool Option 3 setting'. This is copy/pasted from another post in these forums
