AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Firmware Hack And Firmware updates LG LH/LF Series
Firmware Hack And Firmware updates LG LH/LF Series - Page 21
post #601 of 697
VANTWP, i finally could maked it work, the lcd brought a 3.40 version installed, i have to use the 7 times Fav button method to downgrade to 3.15 and usb unlocked.
My question now is, it's possible that i could upgrade to the last firmeware or 3.15 just be fine?
Where i could get the lastest version?
Flip
post #602 of 697
Flip
I have 32LH3000, original fw was 3.15, new 3.15 upgraded - USB anabled I upgraded 3,40 than 3.65 now, works fine.
My friend's was 3.24, first downgrade 3.15 than upg. to 3.24 works fine.
42LH2510 was 3.24, I downgraded 3.15 (USB movie enabled) than upgraded original 3.24, works fine.
latest fw you can find in this forum, read previus.
post #603 of 697
Hi guys! I have an LG TV 32LH3000 with software version 3.40 and I want to update to the latest version, my question is: what are the differences between version 3.67 (latest) and version 3.40? I had the Opportunity to go to the LG service and look to the latest version description. There are only minor differences between versions. (eg: - Improved German language translation.) I am interested in a video codec update. Can someone help?
My mom has a LG 32LD420 which has improved the menu and run some video formats that my tv not read.
another question: Can I install the latest update on my 32LH3000 for 32LD420??
Tnx
post #604 of 697
It looks Like LG are now shipping the 47LD950 with the firmware 3.70.03 which is a update to the original firmware of 3.68.00. The 3.70.xx firmware fixes the issue with the 3D bluRay locking.
"Changelog" posted by flinston:
"Thank you for new firmware! I've tested it and it has a huge improvement over 3.68! . I've had to update with "Expert mode" (go to "Options" and press 7 times Mark button).
What I've seen:
- Good improvement with usb compatibility. Now USB can reproduce mkvs, and you can set in 3D. Still some issues with audio formats that are not recognised.
- DTV SBS now can be put in stereo mode.
- DTV colors more brillant (perhaps subjective )
- 3D Bluray fixed."
p.s. - maybe someone may say if its supported by lh series...
I REMOVED THE LINKS BECAUSE SOMEONES FLASH THIS FIRMWARE TO LH/LS SERIES BUT IT WAS CONFIRMED THAT DONT WORKS WITH THESE TV SETS!!!
post #605 of 697
updates:
from user jenya
@ http://openlgtv.org.ru/forum/viewtopic.php?f=7&t=60
"DON"T FLASH THIS FIRMWARE TO LH/SL SERIES!
The most interesting - it based on MStar Saturn 6 platform.
I flash part of firmware (main executable RELEASE) to my LH3000.
First boot log: http://pastebin.com/FyUG16wQ
Second boot log: http://pastebin.com/tyaNW2ZY
Screen backlight is on, but then RELEASE halt on "Bus error". I assume, that RELEASE can't connect to this device "[i2c]TRIDFMT:2:0x1E" (this string is from RELEASE.cfg)
Before this i have
[SCALER][001019] sc ioctl: unknown command, <-1073450017>
twice. Scaler driver is in kernel.
Next time I'll try to flash kernel, lgapp and lgre partitions from this firmware. And also change Debug mode in Service menu to DEBUG or EVENT (now it's default - RELEASE).
Stay tuned."
post #606 of 697
Hello i flashed the 3.70 to my SL8000 and now it turns on but just grey flickering.
What can i do i tryied to do a downgrade to 3.67 blind but doesnt worked.
can i connect the tv to a pc over the usb or maybe com port? and do something?
please help.
post #607 of 697
@Andreas85
try posting your problem here:
http://openlgtv.org.ru/forum/viewforum.php?f=4
and you will get answers.
post #608 of 697
hi,
i have a lg 32lh3000 with firmware 3.48 and im in the UK
i would like to do this usb hack, i tried to acess the wiki page but it is removed.
can anyone tell me whether it is safe to do this (for my tv with fw3.48) also can someone give me links for the firmwares as the ones in the 1st post do not work.
thnx
post #609 of 697
please help.
Have a look at this post and related posts.
http://www.avsforum.com/avs-vb/showt...3#post17876813
post #610 of 697
hello,
my tv model is 32LH3000
i want to insert my external hard drive into my tv for watching movies and listining to music
i followed the introduction and downloaded Firmware v3.66. after that i upgraded my tv to v3.66
so i pressed in menu 7times the 7 and startet to update. now my tv said "copy of data failed. update ends."
i need help..what can i do now?
post #611 of 697
hello
i have a big problem
after i try to do an update,my tv run with sound only !
the screen do some green and red signal
please if someone have a solution for me
post #612 of 697
How to activate USB (service only) of Lg 26LH20R. I try to do by holding Menu option/ OK of both Remote and TV but nothing appears. Lg LCD Model is 26LH20R, ATR(IN). I also do not know its firmware. I bought it in India. I read ur discovery is not beneficial for Asia. Kindly do someting for Asia too. God will bless u. Thank u
post #613 of 697
You can find out the firmware version entering the diag menu.
post #614 of 697
hi i am looking for a link to firmware 3.55 for a 32lh2000
any help much appreciated as i tried links from earlier in this thread and they are dead!
thanks again
post #615 of 697
post #616 of 697
hey
ive got a 32lh20d-aa,(australian model). ive been reading thru here, and am wondering if its possible to mod these yet?
also ive noticed in one of the menu's, i can change its location designation to american, or europeon. Would this make any difference to modding it?
post #617 of 697
I have PQ2000-ZA, with firmware version 3.38.0, I cant enter the service menu with OK+OK or Menu+Menu option. So I suppose I have to downgrade the firmware with some option? Have a nokia phone, a computer with ir. Is it possible for me to make videos (xvid) play from the usb?
post #618 of 697
Hi everybody,
I have got a LG 37LF2500 and downgraded to 3.15 to activate USB.
Its an European/German Model.
Then i Upgraded to 3.70.03 and after that the Output ist just broken.
See picture here http://imageshack.us/photo/my-images/709/90564345.jpg/
I tried downgrading to 3.15 and 3.55 and 3.67 again but the Output still remains messed up.
Has Anybody an idea what to do?
Regards
Evilmachine
post #619 of 697
@ Evilmachine
Press 7 nine times!
post #620 of 697
Pl did it.
I got an Tv-Software Upgrade Screen. But when i press on Start it only shows
"File not found"
post #621 of 697
Any luck on LG 42PG 3000 USB anabling?
I've been reading a lot but didn'd found it. Help please
post #622 of 697
There seem to be a bunch of people bricking their perfectly good LG TVs again lately... please everyone remember that downgrading/upgrading firmware is dangerous. You should fully investigate and exhaust remote-control methods of entering service menus, known as "IR hack" or other names. There you can enable USB movie playback much more safely.
After that if you are really brave you can try firmware downgrade/upgrade methods, but be prepared to buy a new TV. You can be safer by being sure to have the *exact* firmware file version currently on your TV before you start, then you have a chance to revert using the method here: http://www.avsforum.com/avs-vb/showt...3#post17876813
post #623 of 697
Hi everyone!!!
I would like to congratulate you all on such enthusiasm and devotion.
And there is a question for you all- is there any method to unlock/hack/whatever USB on LG 32G3000? I've turned web up and down but didn't find anything.
Thank you.
post #624 of 697
I have an 37LD450. i just got the universal RCA remote RCR3273N. I do not understand what to do with it to access the menu to enable video through USB.
post #625 of 697
Is there some unofficial firmware for LW series TVs?
post #626 of 697
The latest firmware for lh series:
3.75
http://www.lg.com/ru/support/product...roduct-profile
p.s. - i have installed on my 32lh2000 and its working without any problems.
post #627 of 697
EZADJUST MENU
TOOL OPTION1
"Media Player" line EMF-PM set to EMF
Return
Try, plug in USB... FILM appears?
If it's Ok, please send me e-mal: ltothsz@uze.net
Originally Posted by Rellona View Post
Hi there, I have a european 32LG3000 (not LH) running a 3.20 firmware. If I try to access the magic menu i can only see TOOL OPTION 1. I've used a universal remote already used to succesfully unlock another more recent lg tv. I've also tried with a S60 mobile-phone but it didn't work (mobile's fault).
I tried to downgrade at FW 3.15 posted here (with different usb sticks) but the tv behaves as if I plugged nothing in.
What would you suggest me to do? (factory reset???)
Greetz
post #628 of 697
iIf there is no "Media Player" line:
How to update firmware:
Download
http://www.lg.com/it/products/docume...00_V3.54.01.bi
n
1. USB Flash on FAT file system is need.
2. Download firmware rename to update.bin and copy to USB flash
3. Insert USB into you LG TV (32LG3000) turn on your TV. Wait before
firmware are done.
WARNING DO NOT OFF TV UNDER UPDATE YOU CAN BRICK DOWN YOUR
TV!!!!
http://www.lg.com/es/support/data/so...2010-09-29.bin
Originally Posted by ltoth45 View Post
EZADJUST MENU
TOOL OPTION1
Return
post #629 of 697
HI J flash my 42LH7000 firmware v3.67 with 510907(3.75.00)-LH40_LH90_0.1.57.85_flash_V3.75.epk and cant got tv chanal
trying to downgrade to V3.67 but usb stick file in LG_DTV dont start file only open pictures or move dont see firmware as before last 3.75 Someone help? Thnx!
post #630 of 697
i have heard that lh7000 use different firmware than other lh series (that for fw 3.67)
but maybe i have wrong.
