AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Firmware Hack And Firmware updates LG LH/LF Series
Firmware Hack And Firmware updates LG LH/LF Series - Page 23
post #661 of 697
Originally Posted by rioachim View Post
I tried to force downgrade 3.75 (7 times button FAV) and my tv died. no worry, RS232 restore worked like a charm. so, if you encounter any bugs in 3.75, revert to previous version (only use 7 times button 9)
I made this mistake also now tv will not start! How do I upload the 3.75 firmware again with rs232 port via terminal. Or is ther a quicker way .. Tv model is 26LH2000
Thanks in advance
post #662 of 697
whats with all the talks about irda trick? most of you guys have this tv have high definition anyways right? so if your factory remote not working, use the Rogers one, or the one from your cable operator, i have confirmed it works to enter service menu. all this irda trick is making me dizzy. why do extra work when i believe 90% of hdtv owners have an hdtv box of some sort, most commonly scientific atlanta, or even the bell expressview remote will work.
post #663 of 697
Hello,
I have 37LH3000 LCD TV with 03.63.00 firmware and I want to activate my USB.
Tell me, If I downgrade to 3.15 do the hack and what version should I install after 3.15 ? Witch firmware it's safe to apply ? 3.67 it's ok for my TV set ?
Thank you
post #664 of 697
hi cristu,
just upgrade firmware to v. 3.65 then go down to v. 3.15, do the changes and go up to 3.55. after 3.55 up to 3.63, 3.65, etc.
post #665 of 697
Hello. I saw on LG website v3.75 firmware that has 11.7 MB and another one on openlgtv-org-ru website that has 19,7 MB. What is the diference between the two firmwares? which one is beter for the 32LH2000? Thanks in advance.
post #666 of 697
Hello bobo10,
Can I just downgrade to 3.15 from 3.63 make the changes and then upgrade to 3.55 ? Will I brick my TV set if I do that ? Why should I update to 3.65 first ?
Originally Posted by bobo10 View Post
hi cristu,
post #667 of 697
first install 3.65 then 3.15.
after usb activation install 3.55 then the other.
post #668 of 697
symyady
I have installed version 3.75 from the LG site on two TV's (LD320 and LH5000) and it is ok.
post #669 of 697
Originally Posted by ltoth45 View Post
iIf there is no "Media Player" line:
How to update firmware:
Download
http://www.lg.com/it/products/docume...0_V3.54.01.bin
1. USB Flash on FAT file system is need.
2. Download firmware rename to update.bin and copy to USB flash
3. Insert USB into you LG TV (32LG3000) turn on your TV. Wait before
firmware are done.
WARNING DO NOT OFF TV UNDER UPDATE YOU CAN BRICK DOWN YOUR
TV!!!!
http://www.lg.com/es/support/data/so...2010-09-29.bin
I have tried this with different FAT usb drive. Even found an old 64MB USB, but it does not work. Step 3 does not work
I am still stuck on V3.35.1
Does anyone have another way to update the firmware?
post #670 of 697
Lisame
1. open menu
2. go with selection over "OPTION" button but don't open it...just select it
3. press "FAV" button for 7 times
4. fallow screen steps for update
post #671 of 697
can anyone help me get a site or link to get the upgrade software for my lcg lg42lh3300 tv...I've had it for about a yr and the hdmi has stopped working and the usb never did really, I had no idea you had to update it to get it to work... any assistance will be more than helpful. I bought it in germany since thats where am based likewise ...so its european if that helps....thanks alot guy
post #672 of 697
Yesterday I upgraded my LG 37SL8000 to 3.75 firmware version and now my Smartcard is not working anymore. When I plug it in I got a message box "A SmartCard was inserted", but on setup menu SmartCard option is grayed out and I cannot view my encrypted channels.
How can I fix this?
post #673 of 697
Hay guys,
I am trying to upgrade my firmware to the latest version 3.75 from 3.15 (factory) but the file is not being recognised via the USB by the TV. I have downloaded this off the LG website and followed their instructions to no avail.
I have managed to figure out, after trial and error and largely through this forum that my service screen is accessed by MENU OPTIONS & FAV x7. I have created a file called LG_DVI as suggested and extracted the .epk file into it. B when I access the service screen nothing happens and it doesnt seem to want to find the file. Any ideas?
Tbh is there any point in upgrading it? The only reason I'm trying is that our reception is very bad and has been since we got the machine. So we bought a booster which does help but recently we've been getting all sorts of bother.
post #674 of 697
Hello,
I really hope someone can help with this. My tv seems to have an old software. It doesnt play HD Divx and MKV(not sure if it should)
Here is what I know:
TV: LG 47SL80YR-TA bought from Egypt.
Software Version: I do not know but check attachment.
I was able to get to the software update menu.
I used a newly formatted Fat32 USB Stick.
Created a folder called LG_DTV
Tried with several epk files found on this forum and on russian, portugese and polish LG websites but non seems to work.
I Pressed Menu then Highlighted Option and then pressed 7 times the key 7.
I got the menu attached but it didnt recognise a valid software to update to.
If someone can help me providing a valid software for this model I would really appreciate it. Also let me know if there is something I am doing wrong in the steps I mentioned above, any risks.
post #675 of 697
hey guys.
that folder is LG_DTV not LG_DVI!!!
post #676 of 697
Tried that too. Same issue.
But thanks. Any other ideas.
post #677 of 697
Originally Posted by dalsmaydan View Post
I bought a LG 32" LH2000, for reasons that I could use the USB for playback of multimedia files. I read all the instructions on the internet and" Wikispaces "manual, but first I have a problem that no diagnostic option in the menu that I see what firmware I have. Another problem: any key combination does not work for entering the EZ Menu. Please help me, and sorry for poor English, regards from SERBIAN.
help plz.......i have the same tv....but the first step doesnt work when i press fav 7 times>>>what is wrong,,,is it the firmware,,i used v3.15
post #678 of 697
Hello.
Does anyone know if the latest firmware for LH5000 (3.75) is supporting Nagra CAMs CI+?
I found on some forums some people talking about another LG TV model, a PK model, and it seems that only few countries had CI+ activated. I quote that post
You could also change your country in menu for one country having CI+.
Normally CI+ is available for following countries : France, Italy, Sweden, Finland
If you have a serial cable you could try "rcode" command in debug menu and check.
Here is an extract on my TV set of this command, the interesting part is cip[1] for this countries meaning CI+ activated, all other countries having cip[0] deactivated.
Country {c[0x4652:FR] 4[0] 5[0] C[1] O[0] L[1] V[1] N[0] D[1] A[0] dvr[0] ttx[0] acms[1] dAboost[1] mono[0] i/ii[0] cip[1] f[France]}
Country {c[0x4954:IT] 4[0] 5[0] C[1] O[0] L[1] V[1] N[0] D[1] A[0] dvr[0] ttx[0] acms[1] dAboost[1] mono[0] i/ii[0] cip[1] f[Italy]}
Country {c[0x5345:SE] 4[0] 5[0] C[1] O[1] L[1] V[1] N[1] D[1] A[0] dvr[0] ttx[0] acms[1] dAboost[1] mono[0] i/ii[0] cip[1] f[Sweden]}
Country {c[0x4649:FI] 4[0] 5[0] C[1] O[1] L[1] V[1] N[1] D[1] A[0] dvr[0] ttx[0] acms[1] dAboost[1] mono[0] i/ii[0] cip[1] f[Finland]}
I wonder if this applies to LH5000 too because with my current firmware version (3.69) I receive a message that CAM is not supported.
Also, if anyone have the means and the will to issue the rcode command on a LH5000 with 3.75 firmware and post the result please do so.
post #679 of 697
are all 'one for all' remotes with a magic key compatible?
thanks
post #680 of 697
Hi,
I bricked my TV 42LH4000 via wrong FW two days ago and I'm trying to restore it by the serial port RS232. The TV is on stand-by all the time and it doesn't respond to IR or buttons on the TV. Can you tell me which hyperterminal software did you use? I can't find anything useful on the web.
Many thanks,
Nehat
post #681 of 697
Does anyone know if it's possible to prevent the TV from updating the channel lists?
I've been experimenting with a 19LH2000 and TLLEdit (v4), and am able to delete the radio channels and a few unwanted DTV channels, and it's loaded back to the TV sucessfully, but as soon as a channel is selected, the deleted channels are added back.
post #682 of 697
LG TVs USB Hack
hi guys this is easily solved already. my tv type LG LF 2510 firmware 3.15
materials required: 1>>> 3.5 jack connector,2>>>wire,3>>>remote control led I suggest you start the media player repeat wav file
No need to update the firmware!! just download wav file and pump up the volume smile.gif and enter the service menu.
Edited by Scott Adam - 11/29/12 at 1:45am
post #683 of 697
guys i need help,
i have a 32LG7000 on V03.04.00 but dont find any firmware/tutorial for it...
please help because it sucks not having the media player... or a way to play divx/mkv
post #684 of 697
Originally Posted by vartaxe View Post
guys i need help,
Hi,
try to read this link with Translate
http://www.hifi-forum.de/viewthread-145-2767-2.html
post #685 of 697
Hi,
I have a LH3000 with 3.67 software and with USB media play enabled. Is there an update for newer media/codecs?
Edited by DG25 - 2/4/13 at 4:32pm
post #686 of 697
I have two very important questions guys.
First of all, how do you check your firmware version on LG 32LH2000 ?
And 2nd... Well, I have a sound problem. On regular antenna, sound works fine, but when a cable guy came and got me a cable box(receiver), it didnt have any sound at all. He tried with both of hdmis but they dont seem to work at all, they are just blank. Than, he tried with AV cable, and there was no sound, only picture. I am pretty much runnin' out of solutions here !
ANYONE ? :S
post #687 of 697
Hi Im new here I hope you can help me. My problem is: I've had a LCD TV model 32LD320-UA and I had not wanted to update its firmware but 3 days ago I tried to update it with a firmware that I found on the Russian LG website because I didn't know that that firmware was only for European models and now my TV is totally bricked it it never turned on again and the power led only turns from red to blue and from blue to red, I've searched for the right firmware for my tv, it had the 3.12 firmware version I don't know if there is another version that could work on my TV.
post #688 of 697
post #689 of 697
Hello,
I have at home a 37LH4000 with the factory firmware.
I want to be able to watch mkv, divx etc from the stick.
I'am confused with so many firmware versions, repeated upgrade and downgrade procedures.
I have a simple question: now, in 2013, what is the firmware version I have to install ?
Do I download it from the LG site, or from here?
Do I upgrade or downgrade directly or should I upgrade/downgrade to intermediate versions untill the desired one?
I've read the previous posts and they are a little confusing.
Thank you
post #690 of 697
The latest firmware version for LG LH European TV series is 3.75 (I have the exact same model as yours - 37LH4000 -). You can try Scott Adam's method described here earlier and don't mind the firmware version, or you'll need to go back to 3.15 and access the InStart menu, and then back to 3.55 -> 3.75. Good luck, and read carefully entire thread before doing ANY step.
