A couple of months ago, I built some midbasses:
So I have 2 of those..
Each midbass is using a JBL 2226H driver, net volume is approx. 85 litres, and they are tuned to around 50hz. They are both run by a Behringer EP2500, getting around ~600watt each.
Im always lurking around on this forum.. and always end up with some urge to upgrade SOMETHING.This time I decided that I wanted new front speakers (My current front speakers are some Klipsch RF5s). One thing lead to another - and I decided I wanted to make myself some 2-way speakers, using horns/waveguides.
I got some tips from some forum members here, and started researching a bit about waveguides, and what they recommended.
This is what I have decided on:
- Use my midbasses as the "bottom", approx from ~50-1100hz
- BMS 4555s as tweeter/midrange, approx from ~1100-20khz
- Use my Behringer DCX2496 as an active crossover
- Power the BMS 4555s with my Emotiva XPA-3 (Approx 200watt each)
- Power the bottom end with a Behringer EP2500 (Approx 600watt each)
- Use an appropriate horn / waveguide !
I was originally going for a JBL Horn (PT-F95HF, JBL Pro part# 338650-001).
The US price is approx 100dollars.. That would be around 180$ getting it shipped to Norway (incl. taxes). But according to JBL, I should contact my closest JBL Pro-dealer (Which is located here in Norway)... Well, I did. They want 320$ for just ONE horn..
For the price I sell my RF5s for, I can cover all the costs for both the BMS compression drivers AND the JBL horns. So it's not a big deal for me to pay that much for the JBL Horns.
BUT.
This $20 dollar horn from QSC:
http://www.qscstore.com/hpr152hfhorn.html
Will this be much "worse" than the JBL horn?
Im just trying to "justify" buying the JBL horn.. opinions?
BUT.
