AVS › AVS Forum › Audio › DIY Speakers and Subs › Air Supply's DUAL THT/Small Room Build
Air Supply's DUAL THT/Small Room Build - Page 7
post #181 of 393
Originally Posted by Air Supply View Post
FYI, my hum problem isn't a issue anymore.
I bought that $10 doo hicky from parts express and it removed the HUM completely. It didn't interfere with my HD channels either.
Glad you got that taken care of. Got a link to that doo hickey?
post #182 of 393
Sure, http://www.parts-express.com/pe/show...number=180-075
post #183 of 393
I may try this. I used to have a hum but bought a very dangerous cheater plug that has the ground removed. The hum is gone but each time I touch anything I wonder...
post #184 of 393
+1
You'll want to try to stack them in the corner, mouths together. Make the bottom one upside down and the top one right side up. That way the openings are together.
dbl
No matter, with an 80 Hz passband the mouths only need to be within 3 feet of each other.
post #185 of 393
Congrats on getting one of them up and running. You have me scared man. I told my wife this thing wasnt going to be much louder than my current diy sub. But by the reaction you gave i can tell this is not a true statement . So when are the finishing touches going to be applied? I am jealous of you, but maybe i can make some noise with mine very soon!
post #186 of 393
The correct wording for the wife is not LOUDER. Tell her it won't play louder, but instead it will play material so 'we' can hear it like the director/composer intended (that's what Reference Level is anyway, right?)...make it sound like you are after the director/composer's true 'vision' of the work...not just pure, clean volume...
Oh, and do experiment with placement and measure, measure, measure....
READ THIS: http://www.harman.com/EN-US/OurCompa...ions/13680.pdf
OR THIS: http://www.harman.com/EN-US/OurCompa...s/multsubs.pdf
JSS
post #187 of 393
Yeh, it's definitely going to be louder. I think you tuned your subs around 17hz didn't you? I'd imagine your new build will have much more kick in the higher bass range.
post #188 of 393
Yea 17hz tune with 20hz hpf. No joke you guys are going to laugh at me for this. But i built my THT because i wasnt happy anymore with my bass output. But when i first built my old sub i was extatic about it and was really impressed at the response. My family and i went away on a working vactaion for 2 months. I come home and the first thing i do is pop in my favortie BD and its absolutely nothing like i remebered. It was wierd. Well today i removed the old sub in preperation for the new one and to my surprise i look at the amp gain and its turned all the way down just barely above the minimum haha. Dont ask me how, who, or why but it had to be a very EVIL phantom of some sorts who turned it down. Maybe the wife but dont think shed have a clue at all. I never thought to check the gain or retune the system because the amp was on the back of the box up against a wall so how the heck could it change if I DIDNT DO IT. So anywho i may have just built this for nothing because i WAS happy with my old sub tuned properly. Anyway sorry AIR for putting this OT post . I just thought it was kind of funny.
post #189 of 393
Tried watching Terminator Salvation with the wife. 1st 5 mins was a no go.
Had to shut er down.
post #190 of 393
What'd you break?
post #191 of 393
Those things are ridiculously huge haha. So 2 is over kill huh? I test fired mine in the garage just with some sine waves. Everything was rattling around but it wasnt impressive im hoping in room will be another story. Any final word on the finishes? Im using ruberized undercoating on mine. The first few coats are drying right now.
post #192 of 393
He's going to start cracking the drywall haha.
post #193 of 393
Nothing broke. I didn't get a chance to test anything out, the wife just wanted to watch Terminator Salvation. So, the bass was being ignorant loud. Short story, she got mad, didn't understand that I was trying to fix it and stormed off to our bedroom.
I'll probably just spring for some duratex. I like the way it looks.
post #194 of 393
This is how I currently have my EP4000 setup. Is this correct?
post #195 of 393
I just messed my box up pretty up bad. I had the stuff drying it LOOKED great. But the garage only being half cracked wasnt cutting it for thefumes so i opened it all the way and water fell on the box. It made huge runs down the side of the box so i tried to dab it off where it was the worst in the top left corner and the udercoating stuck to the cloth and ripped off a huge 5"x6" patch. I highly doubt now that i will be able to fix it even close to decent looking. So i may just be making a huge speaker cloth sock for this thing. I hope yours come out great man i dont wish this crap on anyone.
post #196 of 393
Can you not grab some paint thinner remove the runs/cloth?
post #197 of 393
I don't think you will need the direct corner loading.
Also what are you going to do with that front left main? The new subs are going to kill the SQ from it in that position.
Does your wife normally get mad at the drop of a hat, or is it a loud noise hatred thing?
post #198 of 393
Thats what i tried but the coating stuck to the cloth and peeled off the box. So what im left with is 4 decent size runs and 3 bare spots. Im going to try tomorrow sanding and masking around the bare spots and seeing if i cant get a good enough build up and blend it in. Its just a pain in the ass. So next time ill just order the DURATEX and roll it on and leave it. The fumes shouldnt be bad like an aerosol spray can.
post #199 of 393
Well, the subs aren't directly in front of the main. It's diagnal from it. Or, is that still bad? My mains are lacking bad now.
I only had it at -22 before she got all crazy with me. Yeah, she dislikes my "loud" stereo. She just doesn't get it.
post #200 of 393
Undercoating right? I've done some removal off cars before and had to use a grinder. Acetone worked as well, but it's a big giant mess. Actually, engine degreaser breaks it down as well. Shits gross man.
post #201 of 393
She never will get it either. My wife doesnt watch movies with me unless i keep the volume super low. So you could imagine we dont watch many movies together haha.
post #202 of 393
Well if it dries that hard it shouldnt be that bad of a problem to fix. Im just worried when i start sanding it that it will flake and i wont be able to get a good blend.
post #203 of 393
Any surfaces around the mains are bad. The subs seem to be positioned to bank sound directly into the seating area though. There should be a lot of combfiltering going on.
In truth most people will never notice it, so don't worry about it. It was a reactionary post.
Glad it is just that. Well, not glad.
post #204 of 393
Dude, that is how you know that you now have amazing bass.
I can't wait for your listening impressions once you get a chance to really "put the spurs to em' " (...the subs that is...).
BTW that "THT Tower" looks insane...............I like it.
post #205 of 393
AS,
Do you have another place in the theater that you can place those? Maybe in a back corner? I realize that some people don't like that but it's worth a try. If you turn the X-over down a bit it won't be so directional. Either way, they look sweet man!
dbl
post #206 of 393
There is no room behind the couch. I've tried turning the crossover all the way to 40hz on my receiver and couldn't even tell a difference. Something I'm not used to, this thing produces alot of loud mid/high bass.......
hope I the wife goes shopping or something today so I can do some testing.
post #207 of 393
As pissed as you made her sound, she'll probably go shopping for quite some time today. The problem.....REAL expensive shops!
dbl
post #208 of 393
Testing would be very nice, I can only imagine the output you are getting...I would bet you are running the subs pretty damned hot compared to the mains if -22 made someone run away...
JSS
post #209 of 393
I guess this is why horn main speakers are usually recommended with these subwoofers, the efficiency of a horn sub is hard to keep up with for most non horn speakers unless you got some substantial amplification to the mains.
post #210 of 393
Where would you put the mic when testing one of these? At the outlet?
