Originally Posted by
reecew
Im going to use my scrap for that. But i got a question for you. I asked you in my thread but i figured you see it here first. You said your panels were warped also how did you get the final side on? Did you line up the top two corners and then just muscle the bottom into place? Im worried if i do that the screws might crack out of the wood. But i am overly paranoid sometimes.
Yeah, I cut out a perfect 36x36 square for the final side peice but when I laid it on my box, I realized that my box wasn't perfectly square. So, now I have a little overhang and underhang. Nothing a little trimming and bondo won't fix.
My suggestion, cut the side peice a little large. Lay it on top, screw down all four corners, then do all your inside and outside tracing, then trim the leftovers later.
