Originally Posted by GI Joe Sixpack
I know what's in the HDMI 1.4 3D standard, since that is readily available and freely downloadable. HDMI 1.4 does indeed handle many types of 3D displays (but not a true holographic display - I'm sure you simply misspoke). But I have not read the Blu-ray 3D standard, which was the only one I mentioned. I have heard that it does not support quincunx (checkerboard). So it's possible other types of 3D display will be incompatible. One would think that in principle if the player simply outputs alternating left-eye and right-eye frames, as just one example of a possible output mode, it should work with any kind of stereoscopic display that accepts alternating frames, but I do not know for certain what format the xpol displays require the images to be input. Do you?
From My JVC link:
Compatible with 2 different (Line-by-Line and Side-by-Side) 3D signal inputs
