AVS › AVS Forum › HDTV › HDTV Technical › Will Old cable box for HDTV?
post #1 of 5
Will my standard Comcast box be able to get my local channels in HD? Would I be better off just bypassing the box and plugging the cable into the HD LCD?
BTW I am aware there is a HD box.
Also, is it still necessary to rent these things from Direct TV / Comcast?
post #2 of 5
No. Even if it could process the HD signal( it can't ) if it doesn't have HDMI or component it wouldn't output in HD anyways.
Except for a very few options, yes. Even if you could buy one it would cost several hundred dollars.
post #3 of 5
If the HDTV has a QAM tuner, it would at least get the local HD channels. For other HD, like USA, TNT, Discovery, you'll need a cable box or a CableCARD device.
The two currently available CableCARD boxes are TiVo HD & Moxi. See the HDTV Recorders Forum for details on both.
post #4 of 5
great info, thanks.
post #5 of 5
It is recommended you get the HD box. QAM channels give you HD channels, but are unreliable. They change channels very frequently requiring you to rescan on a regular basis. What may be on today may be gone by tomorrow.
Comcast does not sell boxes. Not sure about Direct TV though.
  Back to Forum: HDTV Technical
