AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Help for bad sub location
post #1 of 3
Total newb ? If there is only location to put your sub and it turns out being a bad location does running Audyssey that comes with AVR's help the situation or is there something else?
post #2 of 3
Audyssey will help in any location, obviously not to the extent it would if the subs location was more preferred but it will help.
post #3 of 3
Also you can play with the listening position
