AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › Service menu code for CRT Phillips TV
post #1 of 8
So about 2 years ago our power went out. When it came back on and I turned on my Phillips 19ps45s301 tv, I was prompted with a service menu. Because I am so nosy, I ended up stretching the Vertical ratio of the tv so that it now is too long on the bottom (For example, I can't see the ticker on the bottom of the screen on ESPN because its bellow the actual screen.) I have no idea how to get back to that service menu and cant find codes for my model online. Does anyone have any ideas how to fix this?
post #2 of 8
Try some of these: http://www.riddledtv.com/forums/phil...rptv-t288.html
The first one worked for me on multiple sets. Now, i hope you know what to adjust in there. This time make notes before.
post #3 of 8
Do I enter these codes while the TV is off or on? Do i hit all of the numbers along with the Menu button at the same time or one at a time?
post #4 of 8
TV on, unless the code includes pressing the power button then it must be off at the start of the procedure. You enter the buttons in a row, in the order specified there.
post #5 of 8
i want to know service code of philips crt tv model 20pt2004/94r
post #6 of 8
me too,i want to know service code of philips crt tv model 20pt2004/94r,thank you
RjC5Kx
post #7 of 8
post #8 of 8
agree.unless the code includes pressing the power button then it must be off at the start of the procedure. You enter the buttons in a row, in the order specified there.
8Lw9Te
