Just not happy with what I can do with my logitech harmony 1100.
Wanting to pick up a used control system off ebay to play with and practice programming to hopefully integrate into my theater. All I want to start out with is HVAC control and lighting but would later like to add full AV control of the theater and distributed audio throughout the house with ipod and the other 2 HVAC zones. After that, maybe more.
What control system would you recommend starting with that I could grow with?
What's the differences in the AV2 and the Pro? Is the compact systems enough to start with and expand from there?
. Any processor from an MC2E to a PRO2 will work fine. However if budget permits the PRO2 is a great processor, he can grow with it in the future, and the front panel display and lights can come in very handy for someone learning since you can see if commands are being sent and received.
